Ford 2610 3 pt sway
   / Ford 2610 3 pt sway #1
Saucymynx
LS MT7 101 Farmall 656 Ford 2610 Farmall 140. JD 670
Hello. Does anyone have a stabilizer solution for a Ford 2610/2810/3910? The hitch sways side to something awful. I have a stabilizer bar but that doesn’t work with a quick hitch. The restraining chains are in place but that just keeps it from swaying all the way over end of the tires. My farmall 656 and LSMT7101 have excellent sway control. Any after market solutions? Thanks
   / Ford 2610 3 pt sway #3
I'm not sure I understand the problem. Do you not have turnbuckles on each arm you can adjust? Different width implements will require the turnbuckles to be readjusted to reduce sway. Telescoping units may also be available but may be tractor specific.
   / Ford 2610 3 pt sway #4
When the lower arm balls are shot (really sloppy) or the cap screws that retain them are shot, you get side sway no matter how you set the stabilizers.
if it was mine, I'd buy a new set of lower balls and new bolts and weld them on (after cutting the old ones off of course.). When your balls are shot, things get real sloppy. replacement balls can be had with grease fittings too. One part on most tractors that never gets attention, lower balls.
   / Ford 2610 3 pt sway #5
That series of Ford tractors uses the long stabilizer bars. They go from under the fender mount to the end of the lift arm. If everything is correct, they should work with a quick hitch. Any way to provide pics with what you are having issues with?
No, no turnbuckles or telescoping arms. Never came with those
The balls are actually tight and there is no slop in them. The problem is no stabilizer system other than the bar that connects from a pin under the axle to the implement lower pin after the lower link is attached. It is a big pain in the butt and does not work well. And does not work with a quick hitch. . I’ve not seen any aftermarket stabilizers but that would be the solution. Has anyone seen such things for 2610, 2600, 3600, 3610 etc. etc.?
Thanks. That’s what I have. The just such a pain in the butt and don’t work all that well
   / Ford 2610 3 pt sway #10
my Massey 135 had the same problem, we used a set of these instead of the crappy bars
Tractor is at the farm or I'd got you a better picture, these show what I'm talking about, Tractor Supply and everyone else sells them too
adjustable sway chains
PALLET OF (2) ELECTRIC CONDUIT BENDERS (A55745)
PALLET OF (2)...
2014 Infiniti QX60 AWD SUV (A53424)
2014 Infiniti QX60...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
