rail anvil build
/ rail anvil build #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
Here is an anvil I built from a rail X years ago. I believe its made with 120lb rail, nonetheless, the whole thing is quite heavy and works very well..
/ rail anvil build #2
Nice work, they are handy to have around. Mine sits outside, I need to make a better stand for it. I have it on a cut off log.
ArlyA, do you have a forge? I cobbled one together out of an old propane tank, using a Hair drier for a blower. I played around with knife making, a while back, didn’t get too proficient at it.
Mike
Mike
/ rail anvil build
Mike
Mike
No forges here Mike. My style is more like "need to own Bridgeport" than forge. (I don't have one)
/ rail anvil build #6
You guys are to kind. Its much more funtion than art.
I'd call it both. I have a piece of track a little smaller and one much smaller,neither with a stand near that nice.
/ rail anvil build #8
Mike
Did you pull out for lack of sufficient heat or what ?
If there is enough interest in forges,maybe we could cuss and discuss building gas forge.
/ rail anvil build #9
That wasn’t a problem, i was able to get plentry of heat out of it. I used lump hardwood, as a heat source. I just sort of lost interest and free time for that particular hobby. I tend to bounce around on my interests, doing more woodworking lately.
/ rail anvil build #10
That looks like a really heavy duty anvil and stand.
Good work!
/ rail anvil build #11
That wasn’t a problem, i was able to get plentry of heat out of it. I used lump hardwood, as a heat source. I just sort of lost interest and free time for that particular hobby. I tend to bounce around on my interests, doing more woodworking lately. View attachment 752331
Maybe short of proficient according to who's judging but plenty nice for "playing around for a while".
/ rail anvil build #12
Like your anvil and stand. The stand is least understood and appreciate tool. Necessary part of the anvil to move metal efficiently.
My stand has 8’ of railroad rail, 200# of drill shavings and plasma cutting dust in cement incased in tubing.
Don’t get to forge as much as I like but enjoying particularly meeting some real craftsman.
/ rail anvil build #15
What is the receiver tube in the side used for?
And how do you make a square hole in a rr track?
/ rail anvil build #16
I should add, the base is round so anyone can roll it around to move it if need be.
Very nice feature of an already impressive stand. Smokydog's qualifies for permanent survey benchmark. :giggle:
/ rail anvil build #17
Use mounted receivers to support a shop crane, ring rollers, vises, benders, special fixtures or tooling and other tools that need solid support. Floor space at a premium.
Leg vise has similar base except has caster wheels when tilted back with wheeled trailer jack to move it’s 800-900# weight.
The 8x16” tubing drop was given to me from a neighbor.
/ rail anvil build #19
How did you make the square hole?
Drilled a hole 11/16 because it was biggest drill bit I had, heated end of rail with rose bud torch till high red heat and "drifted" (forced ) square drift through hole... Took several heats over about 3 hours.... Its a Blacksmithing thing...
/ rail anvil build #20
Very nice work!
2012 PETERBILT 587 (A67714)
2012 PETERBILT 587...
More info coming soon (A61574)
More info coming...
Bigfoot with Bottle Metal Decorative Yard Art (A66738)
Bigfoot with...
PORTA POTTY (A67714)
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
2002 PETERBILT 330 VACUUM BOBTAIL (A67714)
2002 PETERBILT 330...
