kioti quit
/ kioti quit #1
bubbu55
North Creek N.Y.
Kioti CK35 HST
Took loader off and went to start and it just cranked, no fire. Nothing obvious, sounds like it wants to go but she won't. Wondering where I should start? Relay symptom maybe? Any advice on where to start would be appreciated. My tractor is a 08 ck35 hst.
/ kioti quit #2
Check that it's getting fuel, no smoke when turning over may be an indication. Does relay for fuel solenoid
Click when you turn the key on?
/ kioti quit #3
Check that fuel flows freely from the tank. How's your fuel filter? Got flow there? Follow bleeding procedure to be sure air is out of lines after you break the lines. Check the air filter. Dirty? Be sure you have a clear path from there to intake manifold. If you have fuel, air, and compression it should go.
/ kioti quit
Checked relays, they picked up but didn't start. I have to check the fuel situation tomorrow. I'll let you know. It did sound like it just wasn't getting fuel.
/ kioti quit #5
Swap the relays and see if there’s any change, after checking that there’s fuel in the tank?!😉
/ kioti quit #6
Check carefully at the places where you disconnected the loader from the tractor to make sure something wasn't pulled out or whatever accidentally. Check that the fuel cutoff valve usually by the fuel filter wasn't pushed shut (if you have one).
/ kioti quit
Checked the air filter, fuel filter, blew out the fuel line from tank to filter, everything seems fine. Put petcock on air to bleed and she cranked normally but to no avail. Fuel is getting to the filter bowl. What happened was I shut the tractor off to unhook hoses and got back on and it just cranked over, I never did get the chance to back it away from the bucket. It seems to me like I hit a kill switch, if you know what I mean. So I don't have to look in the manual, which relays need to be switched around? I have three by fuel tank and two down in front of the tractor.
/ kioti quit #8
Yep, try the 3by the fuel tank. However mark them 1, 2, 3 before you rearrange them so you can determine which one might be the culprit…Keep us posted.
/ kioti quit
Checked relays with multi-meter put power to them and they checked out ok,but I tried switching them around anyway and it just cranks. Should I check the tube from tank to injectors? It just doesn't want to fire.
/ kioti quit #11
Sounds like the fuel solenoid is not opening. The fuel solenoid is mounted to the front of the Injection Pump case. It has a silver zinc finish when new, may be dulled up some by now. Put your hand on the solenoid and turn the key to the "on" position. You should hear and feel the solenoid "clap" open when the key is turned to on. If no "clap", no fuel. The engine will turn over forever but will never fire.
If your solenoid is not clapping, the next step is to check for voltage at the solenoid plug. 12v for one second at the pull could pin, 12v continuous at the hold coil pin. If both voltages are right, points to bad solenoid coil. If one of the 12 voltages described are missing, it will be a control issue (keyswitch, relay, timer relay, etc.).
Hope this helps
/ kioti quit #12
I would suspect the fuel shut off switch.
On a Diesel engine the only way to turn it off is to shut off either the air or the fuel. Normally there is a fuel shut off solenoid that stops the fuel when you turn off the key. I would check to see that when you turn on the key it is opening the fuel.
I'm not familiar with you Kioti, but I have had this issue driving truck in the past. On a steep grade, pulling doubles and the truck just died. I could start it and it would run just long enough to get me about 20' at a time with an occasional near wheelie in the tractor. Long story short, I did this enough times to get off the road, turned out to be the fuel shut off switch had failed.
/ kioti quit #13
Oops! Michiganiron beat me to it! Sorry, I didn't see your post. I have to learn to page to the end of a thread before I reply! but at least now you have a second opinion.
/ kioti quit
I tried the solenoid and it clicked, I thought for sure that was it. I took the fuel filter out and cleaned it, now I have to bleed it,but it just cranks. All I did was shut it off, unhooked loader attachment and tried to start and it just cranks. Gotta be something fuel related but I'm not a diesel mech.,but wish I was.
/ kioti quit #15
Just because the solenoid clicks doesn’t mean the control rack moved to the start position..
If it’s like most of the others, it screws into the side of the case that holds the inj. pump.??
REMOVE the solenoid..
now get a pocket screwdriver or pick and put it in the hole where the sol WAS..
Push on the control rack thru the blind hole & slowly release it.. do this several times until your satisfied that the rack IS OR ISN’T moving..
As long as u have the solenoid out, try to start the engine.. if it starts, u know u found “a” problem..
But u still don’t know if it’s the solenoid itself OR a relay that’s bad..
Good luck
/ kioti quit #16
Hopefully the following isn't your issue...
/ kioti quit #17
You say you removed the loader. Do you think you snagged any other wires when unhooking the hydraulic lines?
/ kioti quit
I didn't move the tractor from the loader after unhooking the hoses to loader, that's when I got back on and tried to start it. When I did test the sol,it clicked louder than normal, at least I think it did but then again the hood is open and I'm closer to it. I'll take it out and do what the pumpguy said, I'm not familiar with the rack your talking about so any info on that would be helpful. By the time I'm done maybe I will be a diesel mech. Thanks guys
/ kioti quit
Took off sol and pushed the armature in and out with little pressure. I put a small drift pin in the blind hole and I didn't feel anything move,it seemed to just go into the same hole as the sol arm. Anyhow I tried to start tractor without the sol installed with the same result. Reinstalled the sol and tried again,nothing. I'm charging the battery now,too much cranking. Should I feel something moving in that blind hole, all I did was push the drift pin in and out but I didn't push too hard.
/ kioti quit #20
U don’t need to push hard..
Visualize what the plunger on the solenoid is doing..
It pushes on a part to shut the fuel off..
Then u apply voltage and it retracts into its housing, allowing the rack to go to start..
It doesn’t take much to move that rack..
Make sure the throttle is in wide open & check it again..
U should feel the control rack moving w your drift..
If nothing is moving, the rack is stuck in the no fuel position..
Do u have a pick w a 90* on one end.?? Or even a circle hook.??
Try to grab the rack and pull it..NOT TO HARD.!!
If u manage to get it free..push on it several times to make sure its free..
Now u can try to start it.
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A67714)
2015 VANTAGE...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
1995 Jeep Wrangler 4X4 SUV (A66738)
1995 Jeep Wrangler...
