1025R Engine to Transmission Drive Shaft Grease
   / 1025R Engine to Transmission Drive Shaft Grease
The Kubota B2601 does not have a Ujoint on the driveshaft. They just carefully align the engine and HST shafts and put collars over the shaft in between. Several other Kubotas are done this way.
Are you offering a trade? It would be a long drive for you but I'll take a summer demo. :)
Heat the joint and fitting with a propane torch for about 15 seconds. That will liquify the grease inside and let you grease it. Don't care for the LNL grease couplers, the barrel is to large in diameter. Why I have the McNaught coupler. Barrel is much, much smaller.
I had never heard of McNaught until yesterday after I bought the lock and lube. I'll test the fit before I install or get it dirty. If I can't get it in there I'll return and get the Mcnope one.
   / 1025R Engine to Transmission Drive Shaft Grease #14
Does the Kubota have flexible (rubber) engine mounts? The small John Deere models have this feature to reduce vibration, hence the need for u-joints. Larger JDs are solid mount and do not have u-joints.
   / 1025R Engine to Transmission Drive Shaft Grease #15
Barrel diameter is very important to me in my application.
   / 1025R Engine to Transmission Drive Shaft Grease #16
Don't know. Doesn't vibrate any more than the 3 JDs I had.
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
KOBELCO SK210LC EXCAVATOR (A55745)
KOBELCO SK210LC...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A55314)
2023 Kubota...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52707)
2017 CASE IH 580...
