Well i broke it this time
/ Well i broke it this time #1
Tchamp
Baldwin Georgia
Power trac PT-2422
Went to lift a tote of wood heard a pop and my forks would not tilt. Upon closer examination i discovered the pivot point on my lifting arms thatcontrol the machine broke….
I guess it did pretty good considering its a 2001 model. 21 years is a pretty good run i think. I wonder if i can get it repaired or i have to order a whole new assembly. I will call PT. On monday and find out.
/ Well i broke it this time #2
Looks like the tube and the internal rod broke as well. Ouch.
You might be better off just getting the entire assembly VS repairing it.
/ Well i broke it this time #3
Sorry to see/hear about it this. I asked Terry at PT about the repair once and he said that the "repair" was replacing the whole assembly.
Speaking as an amateur welder, the repair is not simple, as you would have to cut the right side completely off, cut the pivot arm off, weld it back together in alignment, put a new pivot rod/pipe in and weld everything back up. Do-able, sure, and way beyond my abilities, and I suspect you would need an above average heavy equipment repair guy to do it.
All the best,
Peter
/ Well i broke it this time #4
You don't have too much to loose trying to weld it back in place. If it dosent work, you buy a new one.
/ Well i broke it this time #5
I welded mine back together before it broke. That was many years ago. You could add extra bracing.
/ Well i broke it this time #6
IF I was going to attempt that repair:
Short version:
- Grind pin ends loose from outside of lift arms.
- Slide pin out of tube.
- Remove tube.
- Find new pin of correct diameter or repair pin with welds.
- Slide pin into tube and adjust tube back into correct positions.
- Clean up and tack broken tube welds.
- Remove pin, slide tube into place, install pin.
- Check for free movement with lube in tube, no binds, grinds, etc.
- Hope it's OK. If not, remove and adjust again.
- If OK, then remove and weld tube welds solid.
- Reinstall, test again, tack pin ends in place on outer arms.
- Test again with hydraulics attached.
- Weld pins solid to arms.
The worst part I'd think would be grinding the pin ends out of the arms. If they beveled the holes before they put the pin in place and welded with good penetration, you could be grinding for a while, and might be tempted to use a torch to cut the pin ends out. If you do that, you'll have a lot of material to replace and hope you get the new pin holes square to the FEL arms and pivot tube. So I'd try the grinder and go a bit deep and hope you find the seams before I'd try a torch.
Short version:
- Remove tube.
Talked to steve on keith in Parts at PT the part for my pt is 165.00
Then i just have to grind out the welds, remove pin,remove the center piece and rhen reinstall the new one and then have the cross pin re welded and then done
/ Well i broke it this time #8
That sounds great! Personally, as much I am a fan of welding, I would fork out for a new tube while you are in there, maybe even a solid one. Your local hydraulic shop might have a section of an old cylinder rod in good enough condition to work, and it would be a heck of a lot stronger.
While you are doing the repair, I would also heck that the curl plates are flat and perpendicular to the outer tube when you are done, and I would check that both of the lift tubes are working well, and move freely. I would want to make sure that there wasn't some systematic loading of one side versus the other that somehow might have induced the failure.
All the best,
Peter
/ Well i broke it this time #9
The outer tube is nothing but a spacer, get a good grade of steel bar for the inside weld it up.... It sure looks dry inside, lack of grease maybe the cause...... Jim
/ Well i broke it this time #10
I disagree that it’s only a spacer.
My guess would be the pin runs the full width of the FEL arms outer edge to outer edge. The tube runs the full width of the FEL arms inner edge to inner edge, with breaks where the pin passes through the roll over arms. My guess is that the tube is DOM (drawn over mandrel) tubing and it’s inner diameter is only a couple thousandths larger than the outer diameter of the pin. It’s a foot long simple bearing. That’s why there are grease zerks on both sides of the tube: To put grease between the pin and the tube surfaces.
/ Well i broke it this time #12
I have imagined that the fiddly bit to the repair is welding the outer tube so that the interior of the outer tube is smooth and allows the inner pin to move freely with no high spots. Monster drill? :)
All the best,
Peter
/ Well i broke it this time #13
All the best,
Peter
Yeah. My guess is if you clean it up and make a tight fit to the rollover arms, and maybe not bevel the end of the tube too much, it’s not going to burn through and grab the pin. Of course, that depends on how thick the tube is, how big the hole in the rollover arms is, how much heat you weld with, etc. as you know. :)
I have a reamer somewhere that fits the inside diameter of the caster wheel tubes. I think it’s 1” or slightly larger. They were throwing things out at my old employer and I acquired it many years ago. It’s about a foot long and would reach the center of that tube from either end.
From what I’ve been reading, one of the main problems with these simple bearings is that the wearable material is not replaceable like ball/needle bearings or bushings. And a welded in pin doesn’t help much either. I wonder if they pinned the pin instead of welding it would work? There’s not much rotational force on that pin. It’s just sitting there for the rollover arm tube to roll on. I wonder what the forces the tube puts on the pin are?
Anyhow, it’s a low speed movement. Even if there was a high spot in there pressing against the tube, it’s probably not going to gouge the pin to the point of breaking, and once a path is worn into it, it won’t get any deeper.
That’s my sloppy engineering opinion. 🙃
I’d like to hear others’ opinions on it.
/ Well i broke it this time #14
I was taught that the rule was "drill, bore, ream" in terms of dimensional accuracy. Reamers are so high precision, that I wouldn't want to chance one without drilling and boring it to size. Given the low precision of the bearing, I would stop after drilling.
If you leave a high spot inside the pivot, and it cause wear on the pin, the down sides that I see is that it will a) generate metal shavings that create further wear, and b) the high point will wear a Brooke in the pin, setting it up for fracture/failure.
I am fascinated with the trade offs that PT makes on their engineering. In larger machines, these roll surfaces are generally replaceable pins, but much shorter. The PT solution gives you a broad loader arm with three welded cross braces, for a very rigid frame, at the expense of this particular failure which involves gouging out the end welds, repairing or replacing the pin and pivot and resending the ends. (if you are curious about what can be done with air arc gouging, there is a nice video at
, and
So, to answer your question @MossRoad, I think that the PT solution gives you added strength and rigidity compared to pinning it. One could certainly add brackets on the other tubes to add back strength, but that would probably be at the cost of visibility.
The one thing that I do wish for is a gasket around the ends of pivot to retain the grease and recirculate it between the pin and the pivot. (No, I don't have any bright ideas on how to do that.)
All the best,
Peter
/ Well i broke it this time #15
All the best,
Peter
Yes, I hadn’t thought about the fact that since the pin is welded on both ends it adds rigidity to the center of the FEL assembly. Pins would allow some slop. But a round bushing on the outside of the FEL arms drilled for a roll pin or bolt/nut pin would make it rigid. Or a ring and a taper lock on the rollover pin.
But yes, that would require more complex engineering, when ‘good enough’ works pretty well.
And yes, a gasket would be nice, or maybe a boot of some sort. But, just pump in the grease every 8 hours and you’re good to go.
/ Well i broke it this time #16
First off it is a stupid set up, the highest force is in the middle and it is supported on the outside edge. The pivot arm would need bored out and replace the other tube with a heaver walled one hand weld it on to the pivot arm turn a shaft to fit but first drill and tap for a zerk fitting in the middle. Now insert the shaft though till it is protruding from both outside edges of both arms. Now weld both sides.... Jim
/ Well i broke it this time #17
+1 on adding the zerk in the middle! I also agree that upgrading to thicker wall tubing or solid high strength rod ought to be considered.
All the best,
Peter
/ Well i broke it this time #19
I guess I think on trying to improve it. Plus from my point of view is coming from me having a Lathe, milling machine and meg welder..... Jim
Well what i am doing is i removed the old pin and removed the center pivoting arm assy. The pin in my assembly is 1.234 thick. I purchased 2 foot of 1.5 in roll stock used to make rolling pins on heavy equipment from my local metal fab. Shop. Brought it and the pivot assy to a machine shop, they are going to turn the pin down to fit the pivot assy and then they will install roll pin into pivot assy to align the broken side, align back to original position and weld back together. The roll pin stock was $35.00 the machining and welding $100. Which entails machining the pin, welding pivot arm and welding pin back in place on machine, i think it is very reasonable. I could buy pivot assy. from PT for 165.00 Plus shipping, so it would be around 200 ish im guessing, so i think i am coming out ahead going this route. Plus i am doing good for the environment, im recycling lol.
