JD 850 Compact Diesel
/ JD 850 Compact Diesel #1
nmeister
John Deere 850, Massey Ferguson 1225
The three point hitch on this little tractor has either all the way up or all the way down positions. The control handle won’t hold at any point in between. Any thoughts for a solution?
/ JD 850 Compact Diesel #2
Did you follow the Troubleshooting section in the TM1192 manual? Section 70 & 270 covers this.
Basically, your JD850 in green paint is a Yanmar YM2500. If you can't find anything searching for the JD850, search then for the YM2500.
Under the seat is the hydraulic system. At times a seal, o-ring or gasket could get blow-by.
Those parts in the red circle above are in the TM1192
Then under the seat is the flower looking knob.
Thank you. That should get me going on the repair.
/ JD 850 Compact Diesel #4
Maybe a repair or maybe look at the 'other' controls under the seat. That Troubleshooting section walks you thru those to see if it's a repair of simple maintenance.
For example, you can turn the flower knob both ways until it comes to a full stop. Then place it back to the beginning again.
Next, there is a tiny lever under the seat. If it got bumped, the 3PT lift acts screwy. Here it is on my YM2500/YM2610 aka JD850/JD950. You may need to flip it to various places to change the lift/drop speed of the 3PT.
Lastly before opening up the hydraulic control system, when was the last time the filter and fluid was changed? And if changed, it better be J20C for our Deere and Yanmars. Anything else is crap. Here are 2 formulas that are to the J20C. There are others found at Farm & Fleet, TSC, ASC, and Rural King. It has to 'meet' J20C and not be compatible-with J20C.
Our 2 machines are nearly 95% identical. So, changing the fluid and cleaning the hydraulic filter is identical.
/ JD 850 Compact Diesel #5
More on the hydraulic fluids of J20C are attached.
As Yanmar owners, we keep to the OE specs of Yanmar and Deere.
Shown are both of our machines made on the SAME assembly line with the SAME engine.
  • JD Evolution of Hy-Gard brochure.pdf
  • YANMAR TF500A AND TRACTOR LUBRICANTS.pdf
/ JD 850 Compact Diesel #6
I suggest to check for correct attachment/operation of 3pt feedback rod(item D).
John Deere 6105D Tractor (A64047)
John Deere 6105D...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2019 Freightliner M2 106 26ft. Box Truck (A61568)
2019 Freightliner...
2001 Ford F-550 Flatbed Truck, VIN # 1FDAF56F61ED50387 (A61165)
2001 Ford F-550...
UNUSED JCT 84" HYD DOZER BLADE (A62131)
UNUSED JCT 84" HYD...
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
