Paintball Tips
/ Paintball Tips #1
copytmpmzl
ford raptor
Well, I am about to turn 30 and going this coming Saturday for the first time ever, Paintball Tips.
Well, I have a few questions, and please be honest.
How bad does it hurt? I used to train in kickboxing, and I figured if I can handle that, how bad can it be.
Outfit, well I was never the catalog type, so that's out. Not going to buy it, unless I really get into this and do it regularly. However, I got suggestions and came up with the following. Tan Timerline hiking boots (already broken in), black sweat pants, bring a t-shirt but wear a long sleeve shirt for you want to expose the least amount of skin, and a baseball hat wears backward to help protect the back of the neck. Oh how could I forget: a cup
/ Paintball Tips #3
Any activity that has a device called Dial-A-Welt involved should probably be observed and maybe shot once in the butt from 20' to see for yourself before complete immersion. ;)
/ Paintball Tips #4
i played, make sure you wear goggles!/facemask coat them in spit or baby soap, so they don't fog up.
if your use to shooting a gun, your going to be disappointed they are not remotely as accurate.
keep the gun clean, or it will jam.
within 10 feet will cause large black and blue marks through clothing if hit.
(i took 6 hits to the stomach in a matter of 4 seconds) I was 25 in shape and on the ground waiting for the pain to stop.
its pretty fun though
/ Paintball Tips #5
Are you going to an actual dedicated paintball range, or are these just a bunch of guys running around in a field?
Actual ranges have rules and safety requirements. You will not be able to play if you don't have the gear, helmet, face mask, eye protection. Some ranges make you use only their paintballs. Stops A-hats that do things like freeze them first, or use other ingredients other than paint. They usually specify a power or velocity maximum allowed on the range, as A-hats are also known to crank up the gas output on their guns to increase velocity and make them hurt more.
Just some of the random bits I've picked up by listening to those that go do this kind of thing. I have always given it a hard pass. I don't want to "play" a game where random folks are shooting at me. I don't care if it's a "paintball gun".
Many years ago, some of the kids on my crew wanted me to go with them. I told them I could only bring the one gun, it was an M-1 Garand, and it only has the option of one color of "paint".
You kids have fun out there. But I'll pass.
/ Paintball Tips #6
If your going to a regular range then no worries about frozen paint balls.
It may be hot, but a long sleeve shirt and pants of a stiffer design.
Blue jeans, carharts, ect.... same for a shirt.
If renting, they will supply a face mask as well as the gun. You just gotta purchase the balls which they sell on site.
We've enjoyed it. It does sting, but not too bad.
We've gone paint balling with the grandkids for birthday parties. 3 generations out there shooting at each other.
Where else can you get away with whooping up on your kids???
/ Paintball Tips #7
Years ago, my two sons were always pestering me to take them paintballing. The answer was always no or maybe.
Then, the company I was working for had a "team building day" and they rented an entire wooded rural paintball field and all the equipment, all day, including a big barbecue. I WAS INSTANTLY HOOKED!
I went out the next day and purchased paintball guns for all 3 of us! We would travel up to 2 hours away to play with different teams. Great exercise, great bonding with the kids, overall great experience!
Depending on the distance you are hit from, it can hurt.... from a 'normal' distance, say 20-25', you know you got hit, but doesn't hurt much. I walked up on a guy hiding in the bushes, I saw him and we both unloaded at the same time, maybe 5' away from each other. We both dropped like rocks.
I got hit just above the belt on the far right. Within 5 minutes, there was a 6" diameter bruise with a white center the size of a paintball. That bruise did get bigger and lasted about 3 weeks. Stopped hurting after a couple days. Normal would be a small welt, maybe a slight bruise.
Then I got smart, upgraded my Tippman 98 with a longer barrel, silencer, adjustable gas pressure, and a progressive trigger (the more you pull, the faster it fires in full auto). I would pick out a spot high up on the ridge, and just pick off other players walking by. Lots of fun.
Go try it, keep safety in mind, have fun!
/ Paintball Tips #8
MANY years ago - My son and some of his friends wanted to play paintball games on my property. I have 80 acres - open grass lands, stands of ancient Ponderosa pines, good places to hide and plan surprise attacks.
They were SOMEWHAT UPSET when I made them turn on the irrigation system and hose down outside. Not going to have any of that crap inside the house.
Today it's more about liability and safety. And who might sue who if somebody gets bruised.
/ Paintball Tips #9
For a short time, I had an S-corp with a couple of buddies and we were going to have our own paintball business. Long story, but it only takes one idiot to ruin a business partnership.
The masks are a pain, but losing eyesight is worse. Getting hit can hurt, but you hardly notice it with adrenaline. I have been on team building outings for work where we played. Be careful of fire ants, if applicable. They hurt worse.
Markers, not 'guns'. They are not especially accurate, use 3 shot bursts for better results.
Safety first, but have fun.
/ Paintball Tips
I got hit just above the belt on the far right. Within 5 minutes, there was a 6" diameter bruise with a white center the size of a Paintball Tips. That bruise did get bigger and lasted about 3 weeks. Stopped hurting after a couple days. Normal would be a small welt, maybe a slight bruise.
that's really helpful. thank you so much for your suggestions. i will surely try this
/ Paintball Tips #11
I played semi professionally for a few years. Just worry about your eyes and the idiots around you. Aim like a shot gun. Both eyes open
I use to play in gym shorts and no shirt
It doesnt hurt. Adrenaline takes care of it.
But protect for eyes !
/ Paintball Tips #12
Depending where you are bring bug repellent. Bad season here for the flys and other biting friends.
/ Paintball Tips #13
I think you've gotten some good advice. I've only done it twice. I highly recommend layering up. The last time I played was with a lot of family that had never played. My brother tested out his gun before we started and said, "THAT'S GOING TO HURT!" I'd saying the pain is enough that you're going to openly admit that you're "out" and that you don't want to keep getting shot. It's also going to depend on the ammo. The last time we played, I'd say most of the balls didn't break when they hit us. One of my kids was very disappointed because she wore a white shirt and wanted to be colored.
/ Paintball Tips #14
Loads of fun! I always wore blue jeans and a hoodie. The less exposed skin the better. Face mask and goggles are a must and usually you can rent them at the field. Cheaper to buy your own paint balls than to buy theirs. If you rent their guns they usually make you buy their paint balls.
Also yes wear a hat.
The idea is to make sure when you get shot there is a layer of clothing or two between the ball that hits you and your skin. It will absorb the energy and make it hurt less. I never ended up with much bruising.
/ Paintball Tips
Many years ago, some of the kids on my crew wanted me to go with them. I told them I could only bring the one gun, it was an M-1 Garand, and it only has the option of one color of "paint" and boardgames.
/ Paintball Tips
best paintball mask website
/ Paintball Tips #19
Cover as much skin as you possibly can. Face mask/eye protection a must. If you are going to a commercial field they will rent it. If not that is something to spend $ on. I always wore jeans and a "hoodie" because the hood helped protect the back of the neck. I did not wear the hood up, it was just back there protecting things.
Obviously the pain is water soluble, but wear clothes you do not care about.
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
211771 (A63276)
211771 (A63276)
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59910)
2004 INTERNATIONAL...
2007 CATERPILLAR 966H (A63569)
2007 CATERPILLAR...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
