XR3037H RPM up and down after a few minutes of operation.
   / XR3037H RPM up and down after a few minutes of operation. #61
your machine should have a button to shut off regen temp for goin into buildings ect.make sure its not turned to the stop regen position.i also believe this switch will start a forced park regen also.im not at home right now or could look at mine.
   / XR3037H RPM up and down after a few minutes of operation. #62
Did you find the solution?
If I were you i would get the tractor deleted and move on from the DPF / Regen. There are a few places out that that can walk you through it or there are also some people who will travel to you to do it as well. Its not my place to pass the names on but if you look hard enough you can find them.
This really works pretty well with the Shib 3000 series tractors.
I sure would like to knw more about this. Any direction to find this info would be nice.
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
48ft all aluminum feather light wedge trailer (A56438)
48ft all aluminum...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
