Grand L fel control adjustment maybe?
/ Grand L fel control adjustment maybe? #1
droy
Southwest Louisiana
NH Boomer 55, ZD1211
Sorry for long post,
2013 cabbed 4740, HST+ with 1100+ hrs. Experiencing power loss, engine bogging & slow to recover especially when shredding.
I’m over the road O/O, wife mostly cuts pasture & had been complaining about power loss. Approx year back, two things happened when my job was really busy- algae in fuel, treated, drained tank, r&r fuel water filter (many times).
Also about the same time, one of the fel cables broke, replaced both but not adjusted correctly- have to carefully return control to neutral or it will load up engine a bit.
Yesterday before draining tank (again), I forced air through fuel line at filter, letting air agitate the fuel in tank then let it drain through hose & catching it before filter. Fuel looks good, no evidence of algae. When replacing old filter, I did notice a brown piece of something in filter bowl thought to be but not a leaf particle, approximately 3/16” x 3/16” not the algae sludge I previously encountered. Using a wet dry vac, vacuumed the empty tank- no trash.
Filled with fresh fuel, checked both air filters, cranked & did injector cut-out (loosen injector lines individually), same engine miss for each.
Engine did seem a tad bit more responsive but still sluggish. Using Stall guard, always did for some reason, it slows to a crawl when in some grass I feel it should zip through. Also sluggish moving dirt with fel & bb.
The engine doesn’t appear to have a miss, just feels like a 10 hp loss.
Wondering if improperly adjusted fel controls could be loading engine, (I do notice a difference when controls not fully in neutral) & irregardless would like to get it properly adjusted.
I’m only aware of the one fuel filter, loosened injector lines spraying good; did notice the “bleeder” line on injector pump partially open, closing it makes no difference in performance.
What am I missing? Valve adjustment? Any help / suggestions appreciated, & once again, if I someone knows the procedure to properly adjust the fel control cables, would be a big big help.
Thanks in advance & happy Father’s Day!!!
/ Grand L fel control adjustment maybe? #2
Can't really help much. I'm not understanding the FEL cables loading down the engine -- how does that happen? For one thing, what is a FEL cable?
With boat motors I have found that "enzyme type additive" often clears fuel issues I have not been able to clear other ways. With your history I would try one of the enzyme additives intended for biological contaminants. I use Star-tron Enzyme fuel treatment which is available on Amazon and other places. They also sell (same brand) a concentrate version of it specifically for diesel engines.
Thanks for the reply JWR;
fel = front end loader. The cables resemble sleeved throttle cables, threaded on one end allowing adjustment to let the joystick control function properly.
Have been using Pen Ray brand of algae treatment which local heavy duty parts houses offer. Seems to work pretty good, as too big a dose will quickly cause the dead algae to plug a fuel filter. Will also look at the Star-tron brand as it seems that algae control has become a necessary way of life for most diesel engine owners.
/ Grand L fel control adjustment maybe? #4
Had (2) similar issues recently.
One of my remotes for rear hydraulics was sticking, causing weakness in loader, but no engine power loss. You could hear a slight “hissssss” while it was stuck. Hydraulic oil got hot.
Had power loss similar to what you described. Removed M126X injectors and sent them to a Kubota approved diesel testing shop. 3 of 4 injectors failed. One that didnt was marginal.
Handed it over to dealer. Let dealer replace all 4 injectors. $7,000. Ouch.
/ Grand L fel control adjustment maybe? #5
You gotta be kidding -- injectors are THAT expensive ?
/ Grand L fel control adjustment maybe? #6
Something you might try to rule out hydraulic valve causing bypass over relief valve robbing horsepower: Put the tractor in a loaded condition such as going up a hill and then operate the loader up and down to see if power output changes significantly. I wouldn't think, however, that maxing out relief pressure would load the engine as much as you are describing.
/ Grand L fel control adjustment maybe? #7
Droy -- I knew what an FEL is, I just didn't know what an FEL cable was. You are talking about loader valve control cables from the joystick to the loader valve. Understand now.
Thanks Hay dude, suspecting an injector, but loosening lines one at the time produces a distinct miss which to me means the injector is working, perhaps not under load though. I may have to pull them & bring them in to be tested.
$7000 for injectors is a big OUCH imho!
Just traveling on flat ground & raising bucket will affect power, slowing engine speed.
Correct, I should have used proper terminology.
Can’t find anything on proper adjustment of the control cables, was hoping to find something before I started. Kinda tight with cab. Just gonna set the bucket down on level surface & try to get a good adjustment there. Thought I had it correct when I replaced the cables, but apparently not. Tackling this sort of thing while in a hurry usually has me finding the time to do the same job again, but correctly.
/ Grand L fel control adjustment maybe? #12
How about when you lower the bucket while traveling on flat ground, does that increase engine RPM? If so, that would indicate that you're "going over some relief" all the time.
/ Grand L fel control adjustment maybe? #13
That all by itself is a very wild circumstance -- one I never heard of. Hard to picture what would cause it. That implies that increased load on the hydraulics within a very routine and normal circumstance puts load on the hydraulic pump which loads down the engine. Should never happen. I do not see any kind of adjustment regarding the loader valve or cables to it causing that. If the hydraulic system were into an overpressure causing a relief valve to open ... that gives a whining sound that you would notice AND even if that were the case none of that would secondarily load down the engine. Something else is going on here ... pretty strange. [UNLESS... is this only at a very low engine rpm? Does it still do this at say 1800 rpm ? How much does using the loader slow engine speed? ]
Second wondering: Possibility the loader is plumbed wrong -- in such a way that using the loader puts unusual strain on the hydraulic pump?
/ Grand L fel control adjustment maybe? #14
Thinking about this a little more, the "traveling" part kind of evolved from an earlier post. Actually wouldn't need to be traveling but rather just the engine running at low speed.
/ Grand L fel control adjustment maybe? #15
Disconnect the cables to allow the valves to return to neutral and then try it. I assume you already removed the loader and tried it??
Have you checked the exhaust to ensure it is not partially plugged with soot, a crushed pipe, or an animal nest remnant?
The other thing I would check is to ensure the injector pump timing is correct.
/ Grand L fel control adjustment maybe? #16
An improperly adjusted 3pt feedback rod on my L4060 would nearly stall the engine at idle. I think the hydraulics on most CUTs take around 15hp or so.
Try raising the loader or curling the bucket to the stops while driving or mowing. That would force the pump into relief & to loose HP. If things bogged down, that would be normal. If they didn't bog down any more it sounds likely it was already in relief (and you had valve adjustment problems).
I'd sort out your joystick & cable adjustment sooner than later. Leaving hydraulics in relief makes for a 15hp heater. It will burn up your oil, O-rings & pumps if left unchecked while accidentally engaged. Not to mention the loader doing unexpected things.
Kuhn FC400RG (A60462)
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2019 Freightliner M2 106 Box Truck, VIN # 3ALACXFC8KDLH3612 (A61165)
2019 Freightliner...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
