Best way to clear small trees from pasture
   / Best way to clear small trees from pasture #41
Tordon mixed with glyphosate works well , I have cut and sprayed lots of honey locust willow and osage orange trees with this combo and had very little regeneration.
   / Best way to clear small trees from pasture #42
I just looked up the mixture of "stuff" that works......the trees WILL NOT grow back. (y) :)
the blend I use and recommend most is:
50% triclopyr (Garlon 3A brand name)
40% water
10% imazapyr (Arsenal AC)
Important: Mixed in this order! When you are blending these in a container or bottle, add the Garlon first, then add the water, then add the Arsenal last. If you don’t do it in this order, the blend will form a gel that won’t squirt through the nozzle.
If you don’t treat the stumps with herbicide, you are wasting your time
   / Best way to clear small trees from pasture #43
Why would he need that when the mulcher can push them over and turn them to sawdust? Probably up to 8” diameter. He said it was new growth-like 5 years old. Should be no problem for a mulcher.
I run a 100 HP skid steer and I prefer the bush hog over the mulcher. If I see 3 12" trees growing close together, I let it build speed, blap, they're down. High flow hydraulics are nice. Then I put boom down and tilt hog up and run over all the tops. Switch to grapple and pile it, go home.
   / Best way to clear small trees from pasture #44
I have had success with cutting the sapling/honeysuckle down and painting the cut with straight Roundup®
  • Good Post
Reactions: 462
24017 (A56859)
24017 (A56859)
2007 FREIGHTLINER COLUMBIA TANDEM AXLE SLEEPER (A59575)
2007 FREIGHTLINER...
2014 Grove TMS700E 60 Ton 4 Section Quad Axle Crane Truck (A60460)
2014 Grove TMS700E...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
