BX2200 MMM Deck Noise
/ BX2200 MMM Deck Noise #1
JWR
Elite Member
So MD / WV
MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I have one RCK60B-22BX deck on my own BX2200 and another on my daughter's machine. The daughter's machine was treated rough by a previous owner but in good operating condition since I acquired it for her in late 2014. Her deck is noticeably much more noisy than mine. I'd call it a "rumble" more noticeable on the right side than on the left. I have:
  • Lubed the three shafts well and recently
  • cleaned out any/all debris
  • tightened up the tin lids over the left and right pulley areas.
  • adjusted linkage
  • tightened up & reinstalled the center blade that got loose last season
  • ran it mowing (myself) for 45 min twice recently
  • grabbed the blade and tried to wiggle it from the vertical. No play or looseness found.
  • when bought 8 yrs ago from a dealer, they had replaced one of the mower deck spindles and the belt. It has had routine single family use since then
So I am puzzled at the much greater noise level on hers. Looking at it from the side at full rpm the dual belt is flapping in and out like crazy and at first glance one would say that is what is making the noise -- except that LOOKS the same on both machines. I find the belt tension spring to be tight and stiff but that is just by hand feel. The two belts on the two tractors feel equal just to tug at them.
Anyone have an idea as what may make this excessive noise ? Why it would be so much different between two same-model-same-number decks?
What should I check next ?
/ BX2200 MMM Deck Noise #2
If it's convenient, swap decks between each machine and see what happens with the noise. That will at least make certain that the deck itself is the cause or not. You never know.....
  • Good Post
Reactions: JWR
Good point. That's not easy to do (involves trailering between locations and at my Yuk, age, is no longer as easy as it once was. ) Still not impossible if I fail to get to the bottom of it. True "you never know," but I have not been able to visualize the tractor causing the noise since both machines sound about the same when the deck is not running. Will keep it mind though.
/ BX2200 MMM Deck Noise #4
Another possibility is a spindle or pulley bearing going bad, even though you've made sure it was greased.
The belts can also wear/stretch. Maybe swap just the belts between the decks to see if anything changes.
In the end, if it were me, I wouldn't worry about the noise. If it is a spindle bearing going bad, I would just use it until it (the spindle) breaks. I say that because it's a royal pain to get spindles off, so it's not easy to swap them around for testing purposes.
You've checked everything pretty thoroughly, and there's nothing obvious, so it seems safe to use.
I wear the ear coverings (like headphones) when I mow; that's the best way to fix the noise.....
  • Good Post
Reactions: JWR
/ BX2200 MMM Deck Noise #5
Out balance or bent blade can make some bad noises as well. So does fishing line or other stuff wrapped around spindle not always an easy one to see.
  • Good Post
Reactions: JWR
/ BX2200 MMM Deck Noise #6
Are the blades identical on both decks or does one have stock Kubota blades and the other mulching or aftermarket blades?
/ BX2200 MMM Deck Noise #7
When I had a BX I noticed at certain rpm’s the belt would really vibrate. If running at or near full throttle is smoothed out.
/ BX2200 MMM Deck Noise #8
I replaced the stock Kubota blades with Oregon brand blades this year and immediately noticed how much quieter they are. Might be worth a try.
I did put new blades (Kubota dealer supplied) on the quiet one last season. The noisy one has not had new ones in the 8yrs we've owned it. The dealer put them on when we bought it back then. The blades on the noisy one look the same and not bent or beat up. Good idea worth doing though is to try a new set of blades on it.
/ BX2200 MMM Deck Noise #10
I would check the blades for balance, and it would be a pain, but remove the mower deck belt and spin the blades to check for noisy spindle and idler pulley bearings. Bearings can be tight, but still have rough races that can make a lot of noise. While the belt is off, engage the PTO and see if the drive shaft or gearbox is making any noise.
  • Good Post
Reactions: JWR
Good suggestions. It'll be a few days before I get the thing hauled here where I can work on it beside the other one. Needs doing.
Both have the same Kubota-dealer blades but the noisy deck blades are over 8 years old and the other ones were new last season.
/ BX2200 MMM Deck Noise #13
If not greased every 10-15 hours, the bearings will wear out a lot quicker.
Also, if you let the bearings go, you will wind up wallowing out the pulley bosses by a couple thousand and that will also cause vibration issues, even with new bearings. Which will actually make the new bearings fail quicker.
I typically get 200-250 hours out of set of bearings on my BX MMM before needing replacement. As soon as I hear that bearing noise, I stop mowing and replace the bearings.
Replacing the bearings is easy -- dealing with the belt is not for the faint of heart.
This is from experience and a ton of mowing.
On the non-noisy deck (bought in 2003) I have put 700 hrs on it over the last 19 years. Never touched the bearings. Grease them 2 or 3 times per season. Same with a heavier ground-following Kubota deck on a B2150 I've been running since 1993. Maybe I've just been lucky. No doubt I do not do the volume of mowing you do.
/ BX2200 MMM Deck Noise #15
Wow, "use it until it (the spindle) breaks."
That could be expensive, depending on the deck model?
I suggest OP remove the blade to blade belt and rotate blades individually by hand & listen for unusual bearing noise, as well as check if there is any unusual side by side slack?
(I am not familiar with BX2200 MMM, but the deck drive shaft may also have to be disconnected?)
If needed, spindle bearings are cheap to replace by home mechanic.
  • Good Post
Reactions: JWR
Good input. See post #11. It will be a while before I can get to it but I will be giving it a serious shakedown and investigation soon, including what you just mentioned. Tks.
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
44052 (A55852)
44052 (A55852)
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
(4) UNUSED FORERUNNER 12-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
