Why is my computer losing internet connection in layman's terms?
   / Why is my computer losing internet connection in layman's terms? #21
bad weather
power outage
car accident nearby
tower's line of sight is blocked
snow :) - probably not this month
just needs a re-boot
   / Why is my computer losing internet connection in layman's terms? #22
My old Windows 7 machine has not been powered down since we moved in here, almost 3 years ago.
Why not just turn off the computer when you're done using it for the day?
I think this latest problem started when I went on vacation for a week and turned it off. Every time it is off for a few days it seems like I have a different problem when I turn it back on. Besides that, it takes about 5 minutes to come back on and when you are in a hurry to do your computer chores and then get to other jobs, 5 minutes seems like an hour.
The time before that when I turned it off, when I turned it back on, Edge would not print pdfs anymore no matter what I tried so I had to switch to Firefox to print my pdfs. A few months ago Firefox did an update and wouldn't print my pdfs anymore so I had to uninstall it and install an older version that would print my pdfs. Now every time Firefox starts a screen comes up wanting me to update. If I accidently click on that instead of clicking dismiss, it updates and then I have to delete it and install the old version again.
   / Why is my computer losing internet connection in layman's terms? #25
It is a wired connection. It is very fast but when I use wifi it is much slower.
Thanks. And what operating system are you running, and how old is the PC?
   / Why is my computer losing internet connection in layman's terms? #26
I recommend you install the Adobe Acrobat Reader to handle .pdf files. It's free. They own the format. They really know what they are doing. Either Firefox or Edge will use the Adobe code to display and print, or you can use the reader stand-alone for more print control over the document.
I'm using Windows 10 on a 3 year old Dell XPS. I updated to a HP about a year and a half ago and it was a piece of cr@p so I went back to my Dell.
   / Why is my computer losing internet connection in layman's terms? #28
Are you using a wired or wireless connection from your Dell computer to your cable modem?
I shut off the wireless and use a hard wired connection. Never have problems that way.
If you turn off your computer each time instead of hibernating your wireless will work better.
   / Why is my computer losing internet connection in layman's terms? #29
You should have a program called SupportAssist on your Dell. Run that if you haven't for any updates and to optimize your PC.
   / Why is my computer losing internet connection in layman's terms? #30
Down by your clock in the right hand corner you should see an internet connection icon.
If you hover your mouse over that icon, it should tell you if you have internet connection or not.
You should be able to right-click your mouse on that icon and click disable or enable (as I recall).
So before going through rebooting your PC the next time it loses internet connection, first try hovering your mouse over that icon and seeing the status of your connection. EVEN IF IT SAYS CONNECTED, right click on it and disable it, wait a couple seconds, and re-enable/reconnect it and see if it works. If it does, at least you saved reboot time. If it doesn't then there's probably something in your network settings telling the network connection to sleep after timeout, your network hardware on your PC is getting flaky, or your router is messed up, in that order, I'm guessing.
So as suggested, check to see if your network connection is set to remain connected when the PC goes idle. If you don't know how to do that, you can google something like windows 10 network connection sleep and there are a bunch of helpful tutorials out there about that.
2002 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2002 Ford F-250...
Sterling 9500 (A55315)
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2007 Ford E-350 14FT Box Truck (A55852)
2007 Ford E-350...
44029 (A51692)
44029 (A51692)
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
