Grease.
/ Grease. #2
No - they all seem to drip a little - eventually. Even my nice new DeWalt 18V grease gun.
/ Grease.
Yes. Lube shuttle.
I remember emailing them with this and that's indeed what they said. But I am uncomfortable with the whole proprietary thing. You are locked in to always buying their product because they package it in a proprietary container. So you have to use their dispenser and their greases and you can't ever change without buying all new everything.
I can't reward, with my patronage, any company that uses such a marketing device.
/ Grease.
Wek I did some high end high performance super intellectual internet researh ( AKA google)
I found such a grease. It's called Non-Melt . Mosil Co. has some.
BUT there are issues with compatibility. You gotta purge all your existing conventional grease.
I think I'll live with a few drips.
/ Grease. #8
I hang my grease guns in the garage and in the summer the oil leaks profusely. i have to keep a bucket under them. Ironically, the Amsoil grease is the worst for separation. Seems to drip right away.
/ Grease. #9
I use a lithium based grease for my pins and pivots that I buy from the local Napa store. I don't recall the name, but it sweats on the sides and bottom, however it doesn't actually drip any liquid down to the ground.
But we don't get as hot here in summer as some of you folks do (I say that and it's supposed to be 100F on Saturday).
Anyway, I'll look and see if I have a full one (not in the gun yet) and get a name.
Sta-Lube is the grease. "General Purpose Lithium" Standard tube, in a plain old standard grease gun. Doesn't drip.
/ Grease. #10
Been using Traveler Extreme Duty 3% Moly grease from Tractor Supply for everything I grease, for 20 years or so. I have never had it separate when in the gun or in the tubes.
The $20 a tube Aeroshell stuff speced for use on my Beech Debonair landing gear dripped oil as soon as I put it in the gun and hung it up on the wall.
/ Grease. #11
I use the Lucas red n tacky and I store my cheap rural king Grease gun on some shop towels in the cabinet. It drips a tiny bit. Like two drips per tube ish
/ Grease. #13
Sweet plane. I used to fly a piper cherokee.
A friend had a Cherokee 160, that I put about a dozen hours on. I had it in my hangar for over a month fixing all the crap that his AI never checked, screwed up or wouldn't fix, like an aileron counterweight bouncing around in the wingtip.
After I got it all straightened out, it was a great little plane, had fun flying it around the area, even flew about a dozen EAA Young Eagles in it one weekend.
The Debonair was a great plane, especially after I upgraded it to an IO-520 285HP engine. 160 knot cruise was great.
/ Grease. #14
Most cheaper greases are essentially clay based and probably simply made fluid by using an oil solvent.
Like, don't leave your grease gun stored in a hot location for an extended length of time.
I was once 'gifted' a Lincoln powerd gun and I literally had to drill out the dry caked grease.
It's OK now and my 'go to' gun.
/ Grease. #15
I bought a case of the Traveler Extreme Duty Moly on sale last year but it seems to be thin and separate and be runny. I'm not convinced it will stay where it is needed.
So now I switched to Valvoline Crimson. It's supposed to be an EP grease. Rural King has it for $3.49 vs. almost $7 at Walmart, NAPA, etc.
/ Grease. #16
Red and tacky grease drips quite a bit. The valvoline equivalent to red and tacky also drips quite a bit. I’ve been using Mobile blue grease and it doesn’t seem to drip.
/ Grease. #17
Had a tube of Mobile synthetic grease, that I kept in the basement, leak profusely from my grease gun.
I pulled the tube and threw it away. I questioned its lubricating ability after leaking that bad.
I am looking at getting a Lube Shuttle system myself.
/ Grease. #18
I bought the factory labeled grease from my New Holland dealer, because I wanted everything to be "just right". Last time I bought it, the labeling had changed but it was still their "official" grease. It hasn't dripped any oil.
I didn't expect it to be cheapest, but maybe all things considered it is.
/ Grease. #20
I used Lucas Red & Tacky for awhile but got tired of the dripping. Switched to Lucas XTra HD green and no problems since.
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
ATS Power ATS-RT12R Mini Excavator (A66408)
ATS Power...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
