Best way to clear small trees from pasture
   / Best way to clear small trees from pasture #21
SHORT VERSION: A skid steer with mulcher would be the fastest way to clear an acre or so of 20' to 25' sweetgum saplings. But maybe not the cheapest. Other than using a chainsaw to fell and stack into piles for burning, do you know of another way using a 50hp tractor with FEL? For instance, do you think you should be able to push them over with the FEL? (That didn't work so well but I'm new to FEL on a tractor.)
I have a Woods HC72 6ft rotary cutter on a Mahindra 5010 tractor with FEL which I bought used this year. Several years old but in good shape. I bought 57 acres of land (8 acre pasture) and failed to maintain the pasture. It grew up in brush and weeds and I got all that mowed down (and it was THICK) and it looks good except that I have a boatload of sweetgum trees and other species, but probably 80% sweetgum. They are a hardwood but the wood is pretty soft in the saplings. I don't know about their root structure. They are 1" to about 5" diameter. Amazing how fast that tree can grow in five years! The biggest are 20-25 ft tall already.
I also have some water locust and they have horrific thorns on them. I do not want to use a cutter or mulcher over them because I am scared it would scatter the thorns and I do not want flats on my tractor! I prefer to take them down and pile them to burn, for sure. (Rather than hire a mulcher.) But there are not many of those left, maybe 20-30. Probably hundreds of sweetgum left! Maybe all total, an acre or so left to clear, the rest is cleared and the grass is coming back fast. Fescue and bahia.
I have been taking trees down by hand with chainsaw and dragging them into a pile and will burn them later. But, heck, I have a tractor, so, do you know of a faster way than with a chainsaw? I tried to push them over with FEL but it didn't work so good but I am new to using a FEL. My cutter is not robust enough to just mow them down as it is rated for only 1" stems. Actually, that surprised me and when I first started, I was probably mowing over 2" stems or even a little larger but I stopped that! I read the manual!
I thought I might could push them over with the FEL, dig them, or chain them and pull them out. Or buy another attachment! But that would be too expensive seems to me.
I have been using chainsaw and also a pole saw. They work fine but it's laborious. Sometimes, I use a weedwhacker and clear the grass out from the tree before I cut it down so I can see clear to cut it as flush with the ground as I can. So I can mow over the stumps.
I have a helper sometimes. But I also work alone alot and prefer to have a technique that I can do alone but I'm open to either.
Another option is to hire a mulcher operator. He could do it great, as I did hire a guy two years ago in the woodlot 40 acres in a 3-hr test and he cleared quite a trail in 3 hours. But... mulcher rental isn't cheap. Actually, I thought his $90/hr was a bargain but I have no idea how much his rate is now. As for my helper, he asks for $10/hr and he's a good, steady worker. He and I can whack and pile with a chainsaw each if that is the fastest (or best bang for the buck) method. I mean, of course, the mulcher could do it great but it won't be cheap and my guy could it, alone, just takes longer. But, only$10/hr. Just wondering what you guys think.
I’m in East Texas. Seems like I have cut and have a thousand more to cut, honey locust. The best way I have done it is to cut them about a foot off the ground, then I pile them with tractor. I go back and cut them off at the ground and throw the small pieces on the pile. After cutting them I spray the flush cut stumps with 1quart Remedy 3 quarts diesel fuel. This will kill the root system. I have read if you cut them, persimmon and sweet gum 5 new shoots will come up off the root system. I have seen this up close and personal. If the honey locust are 4“ or bigger I will put pressure on them with front end loader up high. Once I get them piled I set them on fire with a torch. I also wear a hard hat, yes I have had a thorn or two stick me in the head. If I could hire a helper for $10 an hour I would wear them out. Might use two to help me.
@Robert walker ... you first said you cut them about a foot off ground.
- Why? Why not cut them ground flush? Why leave a foot of stump?
You mentioned 3/4 diesel in your mix.
- What does the diesel do, does the mix instructions call for that or have you just found it works?
You mentioned if HL is 4"DBH or larger, you put pressure on with FEL uh high.
- Then what? Are you describing 2 different techniques in addition to felling them with a 1' stump?
thanks!
I wonder if all of these stumps are going to be a perpetual problem without herbicide. I had planned on clipping the pasture 2x to 3x a year after I get it in shape.
Those who mention other attachments, those are interesting for sure. The stump bucket can be had less than $1,000, so, that is most appealing, lol.
   / Best way to clear small trees from pasture #23
You sure those saplings wont grow again after they are mulched? I dont know about sweetgum, but there are some that will sprout right back in a few years. Might be better to strip the top few inches off the entire place with a bulldozer or large excavator and start fresh.
   / Best way to clear small trees from pasture #24
I have a hard time hiring help for $25/hr. Slow and steady wins the race. Treat any tree removal as high hazard work.
I feel your pain. Always having to deal with tree encroachment. Piranha bar, Intimdator, grapples, chainsaws, HD rotary cutter and rehabilitating an old brown tree cutter to help beat back the green horde.
Trees pull out easier in spring. Always have a few planned to push out.
Have changed to pushing trees into piles back into the woods or gullies to rot down instead of burning. Main gully can eat one or two house size piles per year. More environmentally, wildlife, and agricultural friendly.
   / Best way to clear small trees from pasture #25
Southern Land clearing; put a hog wire fence around it all, put about 60-80 hogs in, do not fed them. Stand back and look every two weeks, in 6-8 weeks the hog owner can come get them, load them up. Land will be cleared, leveled, plowed and disked. The brush and grass will all be gone, all trees will be dead and roots will be rooted up. You should have folks around there that rent hogs, that is what they do, those little piggies to rent, they clear land. It is a southern tradition, big hogs make goats look like a joke. Do not fall inside the fence.
   / Best way to clear small trees from pasture #26
Going to either be hard work or expensive. The mistake was made to just let them go. No better time than NOW to get caught up and keep everything under your control. They will be bigger and more labor as well as more expensive next year as the trees and brush will keep growing.
You are not alone in learning that lesson. Ask me how I know...
Now get to work. ;)
   / Best way to clear small trees from pasture #27
This is exactly what a local friend said to me regarding the way he uses his bushhog. What is confusing to me is... there ARE different sizes and capabilities of bushhogs. And, secondly, mine sure makes one hechuva racked when I mow over a downed sapling of any size! It's concerning, I sure don't want to tear it up, lol.
I don't have an adequate fence for goats. I think it would take too much effort to restore the fence. More than I want to expend anyway. I don't have any desire to run cows or any livestock. I could lease if I wished, people call me all the time but I really don't have any desire to do that.
Get some ear plugs. If it's still too noisy, get some ear covers to put on too. Get after it.
   / Best way to clear small trees from pasture #28
I think that is how I would do it but i would back off any tree bigger than your forearm. Just cut the big ones and push in a pile and burn them.
He's got a big enough tractor. Just bounce on them a couple times with a chain, pull them up. Sweet gums will come back forever, I'd pull them. Pull thorn trees too. I've pulled big trees over with a 4x4 truck.
   / Best way to clear small trees from pasture #29
Personally, I would not be concerned about the robustness of your cutter. The duty factor that I have witnessed seems to be associated to the thickness of the deck and the gearbox. If the gearbox has a clutch, then you are good to go. The deck will not be harmed by anything except rust. I have much experience hitting lots of saplings with my 6 footer. As suggested earlier, cut all you can and address the rest with something else. FYI, if you are aggressive enough with your cutter, the point of failure will be a broken blade - broken at the retaining bolt head. What happens is the steel blade flexes at the head when the blade is forced upward from big (3" or more) wood or heavy accumulations of debris that you are expecting it to mulch up. Avoid that big stuff and allow it time to chop and clear debris. This flexing eventually causes fatigue and breakage. I have a spare pair of blades in my barn - currently $120/pr shipped to my door. Also, if I want to cut something larger, like 3", I always back into it, directing the tree towards the rear opening, and moving slowly so the blade tips have a chance to sever the tree as the deck causes it to bend (flex). You could even use this to cut, then the FEL to move the tree elsewhere.
Another tip with saplings is to cut as close to dirt as possible. If a sapling is left to be more than 2" high with a sharpened top, each can become a spear that can penetrate a tire. Ask me know I know, or what I have seen with my neighbor.
As for the Remedy/diesel mix, the diesel is simply a carrying liquid for the Remedy. You change the cost from $80/gallon to $25. It is still very potent, in fact I knock mine down to 20% and use it as a basal treatment, covering 2x to 3x the trunk diameter. Spraying leaves is a waste of product. Cut stumps can be knocked out as well, but don't wait for the stump to dry before treating.
   / Best way to clear small trees from pasture #30
Have the area masticated, then spray the stumps with a herbicide such as Garlon, Velpar, or other products listed for woody vegetation. Use a dye in the sprayer so you can tell which stumps have been treated. Then maintain the area with your tractor and rotary cutter.
   / Best way to clear small trees from pasture #31
It is not cost effective but if I when the power ball I would buy one of these.
   / Best way to clear small trees from pasture #32
Just bush hog what you can. Pull up the thorn trees and bigger gums. Forget about the one inch limitation. My motto is if the front of tractor will ride it over, the back should be able to chop it up. Put in double low and go. Been doing that since 12 or 13, I'm 52 now. Still have the same tractor and same bush hog. Ain't tore up nothing. Cut a few lanes through it and then just half a width each time, much easier.
Yeah, when I first started, a guy at work told me I could bush hog anything I could drive over. He was wrong, there is a lot of stuff I BACK over to bush hog that I won't drive the tractor over.
   / Best way to clear small trees from pasture #33
A tooth bar for your FEL? I have had great success using a root grapple on the FEL. I approach teeth in the ground short of the trunk, breaking up the front side dirt, then approach again with the grapple lifted up high and push the tree over. I would think a tooth bar would get enough front side pentation on smaller saplings. Certainly not as quick as hiring a mulcher, but pretty cheap.
   / Best way to clear small trees from pasture #34
One thing I think that is being seen here over and over, as with many task there may be perfect tool, then often there are a few tools that will work well and then more that will work but say average and not great nor well but will do the job.
The best tool for a job is often the one you have or can afford, as long as you can do it safely and not damage the tool.
I have removed large trees, two to three feet in diameter with a five ton excavator and using thumb or just bucket a lot of saplings also. On smaller stuff I agree if you have space to let it rot do so. It might amaze you have quick the normally rot.
   / Best way to clear small trees from pasture #35
I can probably do 100 6 inch trees an hour with a wheeled bobcat and a set of forks. Probably more than that really. Pine, gum, oak, cedar and others. That includes piling the carnage.
   / Best way to clear small trees from pasture #36
There's a substantial difference between the frame, loader arms, and hydraulic systems on a skid loader vs a tractor. We might be able to mount grapples, tree pullers, etc., on tractors due to the quick attach, but that doesn't mean there won't be a penalty later when it comes to damage to the tractor.
   / Best way to clear small trees from pasture #37
There is a almost free tool that is helpful for pulling trees a bit too large to push over - an old truck tire rim. I push over smaller trees with a toothbar - sometimes after cutting their roots with the toothbar. But I can do pretty well pulling up slightly larger trees with a chain over a truck tire rim that makes your pulling force go up - not out. Works well on many trees. I've found major brush like autumn olive or multiflora can be pretty easily pushed out in damp ground - even when it looks gigantic. Autumn olive, for example, has shallow roots and is a pushover. I get it uprooted - trees or brush -then use the grapple to stack back in the forest to decompose.
   / Best way to clear small trees from pasture #38
The truck tire rim method using the tractor's drawbar (not the rear 3pt lift) and a chain may be least likely to damage the tractor compared to other methods that depend on the hydraulic system so long as one doesn't go too far and flip the tractor.
There comes a certain point where it is safer, faster, and less costly to use a skid loader or dozer.
Having said that, I know two guys who each ended up in the hospital clearing brush with dozers.
   / Best way to clear small trees from pasture #39
Your bush hog will bounce and bang greatly when you go over saplings but it shouldn't hurt it. If the trees are too big you'll shear your "shear bolt" (suggest having a few spares). About those damnable locusts.....they grow back from the roots left in the ground. There is a permanent killing concoction that I read about and tried. It works well, some of the ingredients are expensive but you only need to spray the cut off "stob" or stump. I have hundreds of Locusts and a few "princess" trees that grow a foot a night; no chainsaw could stop them as they grew right back. Good luck
   / Best way to clear small trees from pasture #40
I just looked up the mixture of "stuff" that works......the trees WILL NOT grow back. (y) :)
the blend I use and recommend most is:
50% triclopyr (Garlon 3A brand name)
40% water
10% imazapyr (Arsenal AC)
Important: Mixed in this order! When you are blending these in a container or bottle, add the Garlon first, then add the water, then add the Arsenal last. If you don’t do it in this order, the blend will form a gel that won’t squirt through the nozzle.
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2019 GALYEAN...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
CAT D8 (A58214)
CAT D8 (A58214)
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
