2011 DK50 - PTO will not start!!!??? Any suggestions???
   / 2011 DK50 - PTO will not start!!!??? Any suggestions??? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Hey everyone. I went out this afternoon to grind a few stumps in prep for the concrete driveway and MY PTO will not start. Literally nothing happen when I click the switch.
Any suggestions???
Thanks in advance,
David
   / 2011 DK50 - PTO will not start!!!??? Any suggestions??? #2
First thing I would check is if there is a fuse in the circuit and or are you getting power to the switch. Next are you getting power to PTO coil.
First thing I would check is if there is a fuse in the circuit and or are you getting power to switch. Next are you getting power to PTO coil.
Fuse is good I just checked that, the fuse is common with the 4WD and the green light lights for 4WD, si I think maybe there is power.
I do not know where the PTO Coil is... (Sorry I'm still a bit of a n00b...)
David
   / 2011 DK50 - PTO will not start!!!??? Any suggestions??? #4
Dave,
I can't help on where the PTO valve is on your tractor but would look for valves on the side of the transmission housing. Also no clue on how or if any of safety switches are connected to PTO.
   / 2011 DK50 - PTO will not start!!!??? Any suggestions??? #5
There also is a relay that runs the pto. Its a double relay. On my unit it runs pto and brakes
   / 2011 DK50 - PTO will not start!!!??? Any suggestions??? #6
On my unit it was located under the steering wheel cowling area. You can go to michiganiron website and look up electrical schematic on your unit.
   / 2011 DK50 - PTO will not start!!!??? Any suggestions??? #7
Let me find pics
There also is a relay that runs the pto. Its a double relay. On my unit it runs pto and windshield wipers
No cab, no windshield, no wipers.
Sorry,
David
   / 2011 DK50 - PTO will not start!!!??? Any suggestions??? #9
Sorry. Meant brakes
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2019 FREIGHTLINER...
2018 CAT 259D Skid Steer (A54865)
2018 CAT 259D Skid...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
