John Deere Seat switch
/ John Deere Seat switch #1
JAMES NICHOLSON
lisbon.ohio
cub super lt1550,ford lgt 100,simplicity,wheel horse, murry
I have a John Deere X350 and when mowing on a slight slope if I lean over a little the seat switch cuts the mower clutch off. Is there any way to disable the switch or fix the problem ?
/ John Deere Seat switch #3
On my JD mower, I discovered that the seat switch is NO (Normally Open) without a rider, so when one is seated, it makes contact for the two wires that go to it. The seat has a wire connector somewhere close to the seat. I unplugged mine and inserted a small copper wire across the two contacts, in essence creating a jumper (same as what @Hughman is saying).
/ John Deere Seat switch #4
I did the same thing on my X300 by making a jumper between the contacts in the plug. I also disabled the RIO by unbolting the switch from it’s mounting position and zip tied it to the frame, so it stays open all the time without needing a jumper.
/ John Deere Seat switch #5
... I also disabled the RIO by unbolting the switch from it’s mounting position and zip tied it to the frame, so it stays open all the time without needing a jumper.
Please explain the RIO issue in detail. I once had an X749 but sold it. It was super annoying that the mower would shut off upon reverse. I looked all over for a solution and found nothing to override - figured it was a switch inside the transmission.
/ John Deere Seat switch #6
On my particular X300 the switch was located under the foot board of the mower body on the discharge side below the reverse pedal. When depressing the reverse pedal it pushes on the RIO switch and kills the blades. I just unbolted the switch from the frame and moved it away from the reverse pedal instead of trying to unplug it and use a jumper like on the seat switch. Because of where it’s located, plugging the switch would mean both ends of the switch would fill up with grass, dirt and water. So it made more sense to leave the switch intact and just move the switch out of the way where it would not get engaged.
/ John Deere Seat switch #7
/ John Deere Seat switch #8
RIO jumper. Blue & yellow to blade engage switch on the x500.
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A64557)
2006 Freightliner...
2002 Sterling L7500 Series VacCon V390LHA Combination Sewer Jetter Vacuum Truck (A64556)
2002 Sterling...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
GREAT PLAINS 2400 TURBO CHOPPER (A64278)
GREAT PLAINS 2400...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
