Ferguson 14A
/ Ferguson 14A #1
Rdw1121
Texas
Kubota L3302
I don't know much about moldboard plows and I have found a Ferguson 14A 2 bottom plow. I have seen mixed information on the minimum HP need to pull a these and some people having trouble with hooking them up to a Kubota.
Will this hook up to a L3302 and will it pull it? Are replacement parts available?
/ Ferguson 14A
Here is another picture from the moldboard side. They are asking
/ Ferguson 14A #3
Tractor capability is more closely correlated to tractor weight than any other single specification.
It is more about tractor weight, which determines tractor TRACTION, rather than tractor horsepower.
Yes, a 4-WD Kubota L3302 will pull a Ferguson 14A2 2-bottom plow in good condition through moist soil just fine.
The Lower Link pins are a different heights on moldboard plows. You will need to adjust your TPH right Lifting Rod by screwing adjustment on right side in center, in or out, in order to mount the plow. Not difficult.
Creating beautiful furrows takes a while to learn. Persevere.
/ Ferguson 14A
Thanks Jeff….
/ Ferguson 14A #5
Yes. But as not many new plows are sold these days, replacement parts may take some shopping. If that Ferguson plow is in unaltered / unbent state it should invert soil for fifteen to twenty years without needing wear parts, plowing in reasonable soil.
The Ferguson plow you picture is around 70 years of age.
VENDERS: moldboard plow wear parts
I don't know much about moldboard plows.
PLOW BOOK: Harry Ferguson TO-20 30 Plow Book 3pt Hitch Tractor Moldboard Plowing Manual | eBay
* Operation And Care
* Remove Paint And Varnish
* Adjustment Of Rolling Coulter And Jointer
* Adjusting Width Of Cut
* Rear Furrow Wheel
* The Top Link
* Lubrication
* Causes Of Bad Plowing
* Plow Shares
* How To Attach The Plow
* How To Detach The Plow
* Headland Furrow
* Entering The Furrow
* Leaving The Furrow
* Finishing A Land
* Suggestions In Laying Out Fields To Be Plowed
* Back Furrowing
* Finishing Irregulary Shaped Field
* Plowing The Field Turning Square Corners
/ Ferguson 14A
O wow that’s a huge help.
Thank you
/ Ferguson 14A #7
From your photos it looks to me like the plowshares have both been replaced. Rust us the enemy of all plows. Try to find a place where you can store it in the dry and put some scrap wood or ? under those plowshares to avoid rust damage. I think you can pull it without much trouble but you will need to spend some time playing with it to get the behavior you want.
/ Ferguson 14A
I haven't went and looked at it yet, its 4-1/2 hrs one way from me. So far its the best looking one I have seen under $1000.
/ Ferguson 14A #9
Good heavens you should not have to pay that kind of money. There have to be a lot of old 3pt hitch configured 2 row plows around. Pretty much no demand for them anymore as farming on larger scale uses much different tillage and on a small scale they are out of business, only do it as a hobby, or don't deal in equipment any more. At some point in history there had to be more of those "3pt , 2 plow" units around than any other kind. Don't know about Texas but in the east places like WV have a statewide "Market Bulletin" where individuals advertise farm equipment, often older stuff. Tried Craig's List or similar on-line sources?
/ Ferguson 14A #10
Plow shares were difficult to find. Mine came with deep sink shares - long front tip draws the shares into the ground quickly. Broke one on a rock. I eventually found an Amish person who makes them for more than I paid for the plow, $260 if I remember. I found replaceable shares with close fit on line. It took drilling and countersinking a new hole in one place but back working. In the meantime I bought a King Kutter 2 bottom new - it turned out to be a piece of junk. Ferguson much better but you need to search for, and greet creative on parts.
/ Ferguson 14A
The new ones and even some restored Ford trip plow on ebay are $1300 and up. It see them in Pennsylvania, Ohio, Indiana and Kentucky they appear to be in good condition and $200 to $300. That Ferguson is down close to Victoria and its $450.
/ Ferguson 14A
I have thought about buying a new plow but I don’t think the quality is there compared to the price.
/ Ferguson 14A
I did find another one craigslist it was $400. The colters were missing and the moldboards and shares looked pretty rough.
/ Ferguson 14A #14
It is hard to judge condition from pictures ~~~ but in my opinion a fair price for the plow.
The clinker is your nine hour round trip expense to pick the plow up.
2006 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2006 V.E...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A61568)
2016 Ram 4500 Crew...
2024 JCB 35Z (A60462)
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
