MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,314
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Folks, leave the political comments out of it, or the thread will be sent to the front porch/closed. Thanks.
YepNope
And THATS the cause of the higher pump prices and the higher pump prices make ALL products more expensive because EVERYTHING is produced and shipped with fossil fuels!^^^yes^^^Theres a war on fossil fuels.
No, it's not. It's almost 100% supply and demand.And THATS the cause of the higher pump prices and the higher pump prices make ALL products more expensive because EVERYTHING is produced and shipped with fossil fuels!
Oh, ok. If Forbes says so, it must be true.No, it's not. It's almost 100% supply and demand.
Oooo, I've got some good zingers for that statement. But alas, no religion or politics.I believe what I see, not what I read.
search for the following phrase:
"what's the cause of high fuel prices?"
It would be great to see it moved to Front Porch. It needs to beFolks, leave the political comments out of it, or the thread will be sent to the front porch/closed. Thanks.
What an uncalled-for, irreverent comment to make. You really think I want people to suffer?I’m sure that you’re rooting for that to happen. We have never experienced a rolling blackout in my state even with 36% of power from renewables. The only blackouts we ever experienced in the past 20 years were due to weather events such as snow storms, wind storms, tornadoes, substations failing…. Those rolling blackouts always seem to happen in the same places, indicating those areas have other issues with their power grid.
There's no way possible that you could have read that article. I posted it, saw the political comments, edited it out, and you had already replied to it. Less than 60 seconds. Because it said Forbes, you immediately dismissed it without reading it. Well, that's why I offered the alternative to do the search yourself and see what other articles/evidence you come up with to support the position that it's not supply and demand driven.Oh, ok. If Forbes says so, it must be true.
Supply on fuel is down suddenly 1.5 years ago and more than doubles in price starting a year ago and nobody thinks it has anything to do with policies?
Ahh. Another conspiracy. Explains everything.And THATS the cause of the higher pump prices and the higher pump prices make ALL products more expensive because EVERYTHING is produced and shipped with fossil fuels!
You don’t own a power company utility, so what you would rather do is irrelevant. The power companies made their informed business choices on their mix of power generation sources and it works well. There will not be rolling black outs across this country due to renewables or anything else, short of local things like wildfire and weather events that damage infrastructure. You see, power companies build something that they call redundancies into their systems. They spend quite a bit more time and engineering into their systems. But I suppose you think you know better than their legions of engineers.
Both natural gas and wind power failed. Because the systems weren’t designed for cold weather. It was a gamble those companies took to save money. Because it never gets cold there.Just recently did not Texas have a very cold period the caused power outages? It seems the conventional power sources failed whereas solar and wind kept functioning.
The problems Texas had was because they failed to prepare the way they were told to. Because, you know, that would cost money and be hard and stuff. To their credit they’re a leader in clean energy. They generate more electricity with wind and solar than they do with coal, although about half comes from gas. Places like west Texas, where the only things that grow are rattlesnakes and tumbleweeds, are absolutely ideal for both wind and solar.Just recently did not Texas have a very cold period the caused power outages? It seems the conventional power sources failed whereas solar and wind kept functioning.
Keep in mind that oil fields have surface areas around well heads, surface area for transportation systems, surface area for refineries and storage. All these aspects of hydrocarbon also require many mined resource products for materials to build them. Consider how much steel and what type would be required for a bore hole 5000 feet deep that produced hydrocarbons containing hydrogen sulphide.
We should also be aware of damage to the environment from hydro carbon processing and use.
Both natural gas and wind power failed. Because the systems weren’t designed for cold weather. It was a gamble those companies took to save money. Because it never gets cold there.![]()
The most daunting challenge for nuclear power is than no state will commit to hosting waste disposal facilities. Nobody wants that. It was even opposed at yucca mountain in the Nevada desert.No, it was the better choice based on the odds. You could prepare for tornadoes in Las Vegas, too, but they are so rare as to be non-existent. Hindsight is great and all, but the biggest problem with power generation in the US is the woeful lack of nuclear plants. Opposition is due to fear mongering and misinformation. Much of that is due to the misconception that 3 mile island caused a major disaster. The was virtually no impact to that other than the suspension of future nuclear plants in its wake. I've got little problem with wind and solar as supplements, but both are, and always will be, unable to produce power on a consistent basis.
