feeling stumped--advice needed
/ feeling stumped--advice needed #1
BLSXJ
Gold Member
Pembroke, Ontario
Kubota L3400
I just had 2 acres of forest cleared with the goal of pasture. My contractor was supposed to use a mulching head on his excavator (18ton) to mulch everything 4" and smaller down to the ground. Pull the larger trees, mulch the tops, bury the stumps and leave me with log piles.
Well.... due to the abundance of rock... mulching stopped 6-8" above ground and burying the stumps was a no go.
What I have now is 2 acres clear, all the stumps have been pulled (for better or worse). and piles of brush, stumps and logs.
He did offer to mulch the brush piles.... but in fear I now would have to burn the stumps I told him leave the brush.
What do you recommend now for piles of pulled stumps?
I'm on a limited budget and have 30hp tractor, 6" wood chipper, pallet forks.
from what I can tell my options for the stumps are
hire a tub grinder ($500/hr)
truck them to the dump ($100 per ton or ~$20 per stump form experience)
burn them (almost free but very time consuming due to fire limitations)
We went way over budget with contractor #1.... I should have sent him away after day 2 and bought my own excavator.... but focusing on moving forward...
NOW WHAT?
just to clairify
I have piles of stumps, piles of brush and piles of logs. each separated... multiple piles of each scattered
/ feeling stumped--advice needed #3
I’d pile everything and burn it. It’s by far the most cost effective option. If they did a decent job piling it and it’s not half dirt it should burn pretty easily.
/ feeling stumped--advice needed #4
I burn them, then find a ditch to bury the stuff that won't burn. If you put them in a brush pile and it burns well, you can move them to the next one, and they will burn a little more.
If you have tons of rock and stumps, a dozer might be better than an x. If you could only run the mulcher down to 6-8 inches it will be tough if not impossible to brush hog, seed, or anything?
/ feeling stumped--advice needed #5
I understood the post to say they mulched the stumps and then pulled them. If the stumps are in the ground the op has a big mess.
/ feeling stumped--advice needed #6
Burn the brush piles. Stack the stumps/root balls in a far corner and forget about them. My experience with root balls - they don't burn. I bury them or push them into a pile out of sight.
What's the plan for the two acres? If you're building a house you'll have plenty of spoils you can use to bury your root ball pile.
/ feeling stumped--advice needed #7
Smaller ones like 12”-16” inches that you can get the dirt out of will burn pretty good. Big ones that are full of dirt won’t burn.
/ feeling stumped--advice needed #8
On mine, i dug a huge pit and placed all the stumps in there. Then i burned pit over a year, adding dead trees and brush. This burnt the roots down considerably. then i buried pit. That was maybe 10 years ago. Pit settled a bit, i added some dirt. Now i csnt recall where pit exactly was.
/ feeling stumped--advice needed #9
I can't seem to find the links, but I recently read some articles on open burning that said larger piles were more dangerous, the fires may not be completely out for days, and the level of risk varies with the dryness of the materials nearby. As I recall, the articles said it was less risky to burn after May when vegetation was in full growth and full of moisture. You'd need to carefully assess your situation and what is around you to come up with a plan that's safe for you.
/ feeling stumped--advice needed #10
Burn it.
anything that is not otherwise useable (firewood) ... just burn. It will take time, start with the smaller piles so that it feels productive over time. Do the larger burn piles when you have more time. To reduce the occupied space, maybe amalgamate the piles as you can.
ok my township will only allow burn piles 4x4x4 feet (thats with a special large burn permit)
looking at the piles of material.... I dont know if I have that much time...(I'm 39 and I'd like this done in my lifetime)
Digging a hole is near impossible between the shallow bedrock and large boulders
Anyone ever use a fan to force feed a fire? I'm thinking trench with a large fan at one end
/ feeling stumped--advice needed #13
Pasture ?? Only two acres or is there more land? Get a soil test of the land. You might want the ash from burning the brush & debris for a soil amendment. Wood ash in the right soil adds potash and adjusts the pH. (Ash is alkaline)
You missed a good deal by passing on mulching the tree tops. The mulch is good for adding organic material to mineral soils... What you have after clearing woods.
Wood burners are a metal tube with a fan on the end. Very effective for burning land clearing debris.
/ feeling stumped--advice needed #14
too close to Summer and burning bans for me
not too late.... the miss's can feed the wood chipper we own at only the cost of fuel ($7US/gal here 2.35cdn/liter)
/ feeling stumped--advice needed #16
I have 30hp tractor, 6" wood chipper, pallet forks.
Burn.
Eradicate all dry grass around debris piles down to dirt.
Wait until you have had rain so nearby vegetation has taken up water.
Wait until your wood branches have dried and a near wind-less day is forecast. Ignite. Cautiously push up smoldering debris with your pallet forks in 4-WD and low gear.
I maintain a community burn pit. I ignite homeowner yard debris at least once per week. It rarely takes more than a week in warm/humid Florida for hardwood stumps to convert to ashes.
/ feeling stumped--advice needed #18
I have burn my brush piles last year it burn quickly but the stumps smoldered for months, it was a very dry summer but no firer ban, I was suppose to get permits I believe but I didn't, id light them up at dawn and it looked like if it was out by the morning but any wind or rain and you would see the smoke coming out again. I would do the same bring some brush to the stump piles and light them up at nights over and over until you ether burn them all or you run out of brush to feed the stump fire and call it your ''camping fire'' you just felt like having a big one that day that's all, if not like other said put them in the corner of the property and let them rot. Or get your permit and make multiples 4x4x4 fires and light them up all at once ....
/ feeling stumped--advice needed #20
So you're clearing guy isn't from around there, or you're geology is very unique to the area?
Seems to me that if both of those are a NO, it's on him and should have realized this in the first few days if not hours. Actually he should have had a suspicion during his field walk for figuring his price and informed you that was a possibility.
Sorry about your luck with this one.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
