FEL joy stick.
/ FEL joy stick. #1
Ohio RK24
2019 RK24
Howdy folks,
I have a quick question about the FEL joy stick on my RK24. It seems that about once every year, I have to tighten up the the nuts that hold the joy stick to the actuator assembly.
Has any body ever applied lock tight to the threads before installing the nut to prevent them from working loose?
/ FEL joy stick. #2
I have done so on other machines. There's no reason it would hurt. Anything to dampen the vibration getting telegraphed to that handle should help.
/ FEL joy stick.
Thank you for the info, it. is much appreciated.
/ FEL joy stick. #4
Teflon tape will do the same for you if you have that handy and not the loctite.
/ FEL joy stick.
Great to know, I always have some teflon tape at hand as I live in a very old house. Never a question of if I will need it, just a matter of where. I have in the past used to make up for over sized screw holes in wood.
Thanks again.
(INOP) 6' FINISH MOWER (A62130)
(INOP) 6' FINISH...
2022 Kobelco SK85 Excavator (A61166)
2022 Kobelco SK85...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2018 INTERNATIONAL...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2010 Honda Accord Sedan (A61569)
2010 Honda Accord...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
