Why no hydrostatic transmissions on larger tractors?
   / Why no hydrostatic transmissions on larger tractors? #21
Mainly because of the heat generated, the noise, the inefficiency, and short lives.
More horsepower aggravates and increases all of the above.
That's the long and the short of it right there!
SR
   / Why no hydrostatic transmissions on larger tractors? #22
I’m not sure about reliability being a factor. My dealer’s service manager told me they replace far more clutches on gear tractors than they see HST problems.
Not surprising considering that US and a simple clutch don't go very well together. At least for most people.
Around here, it's not uncommon at all to get anywhere from 3000 to 4000 hours on a clutch. Some more, some less, depending on the type of work and the operator of course.
   / Why no hydrostatic transmissions on larger tractors? #23
Meanwhile, my Payloader has 13,000 hours on its "unreliable" hydraulic transmission. It is on its second D466, arguably the most reliable mid-size, straight-six diesel produced.
   / Why no hydrostatic transmissions on larger tractors? #24
One they brought to me, I was told it wasn't quite going into reverse. 24speed hydrostatic. I took it down, reverse was not there. Shopping the first three parts had me at 5500 $. Bought another tractor with gear shuttle and swapped shuttle unit over. Much cheaper and much better. I think it was a 1455 Massey Ferguson. Been a few moons. Had a six cylinder Perkins.
   / Why no hydrostatic transmissions on larger tractors? #25
Doesn't your machine use a Torque converter coupled to a power shift transmission? As far as the engine, from what I've seen on the internet, those things run forever along with the Cummins 5.9 with just basic maintenance.
   / Why no hydrostatic transmissions on larger tractors? #26
You are correct. Basically the engine runs three hydraulic pumps. One for the transmission, one for the steering, and a big one for the loader, and third function which is rated at 42 gallons a minute or the ability to cycle up and down 31,000 pounds in seven seconds. My machine was made for loading on-road running dump trucks and logging operations.
   / Why no hydrostatic transmissions on larger tractors? #27
Great location. Offen went to Nevis in the 60s/70s. Lake Belle Taine. Look up Beauty Bay Lodge. Grand parents build it in 1946...
   / Why no hydrostatic transmissions on larger tractors? #28
Don't know about the OM617, huh? ;)
   / Why no hydrostatic transmissions on larger tractors? #29
   / Why no hydrostatic transmissions on larger tractors? #30
Many larger tractors are available with Shuttle feature which gives you Reverse in whatever gear you are in. Very handy in certain circumstances.
2019 GALYEAN...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
Torro Groundmaster 3280D Riding Mower (A59814)
Torro Groundmaster...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
