Kubota L3710 runs for 20 minutes then won't run at speed or at all.
   / Kubota L3710 runs for 20 minutes then won't run at speed or at all.
One thing that I forgot to mention, because I didn't think it was important, but when it first did this weirdness, I pulled both side covers off to see if anything obvious was going on and found the rubber oil plug on the left side of the engine had blown out. The plug is old and age hardened and really doesn't fit that tight anymore, so I thought it probably was not related to the issue. I wrapped a thin rag around the portion that fits into the hole and tightened it up.
   / Kubota L3710 runs for 20 minutes then won't run at speed or at all. #12
you never know....sometimes the simplest thing can cause the problem.
if it were me, I'd put a proper plug in there before doing anything else.
Also...is your oil low?
  • Good Post
Reactions: JWR
   / Kubota L3710 runs for 20 minutes then won't run at speed or at all. #13
is the radiator getting hot? water pump pumping?
may be time for a compression test when cold, then right after its running rough/quits.
oil plug is evidence of crank case pressure, blow by.
seems to be heat related if it sits and comes back to life. test the injectors? I have heard of injectors that run well cold, but when they get hot do not.
sounds like you have covered the fuel system pretty well. have you checked the oil in the injector pump, if it is a separate thing to change like some, for evidence of wear.
The oil was right up to the full mark on the dipstick.
The engine is not overheating at all. The temp gauge works (gets to the first white mark on the gauge) and I just cleaned all the gunk out of the radiator core last summer because the temp was getting too near the red on hot days.
How does this engine ventilate the crankcase? Does it have a pcv valve setup like the gasoline car engines used to?
Also, I think the cams and followers oil off the crankcase oiling system. I've never seen any reference to the injector pump cams having a separate oiling system.
   / Kubota L3710 runs for 20 minutes then won't run at speed or at all. #16
Check and make sure you are getting good flow in and out at the filter. Could have a fuel line braking up inside.
I have flow all the way to the injector pump. I replaced all the feed hoses and the lifter pump, took the filter assembly apart and cleaned it. I did find a chunk of dirt in the shutoff selector and thought for sure that was causing the problem, but it still happens.
   / Kubota L3710 runs for 20 minutes then won't run at speed or at all. #18
Now that is something that I had not thought about. Not even sure how to check it, but I'll give it a whirl tomorrow. It does blow black smoke when I try to start it after it dies. Then after it sits a while it cranks right back up and runs great for another 15 - 20 minutes.
To check for a restriction, take off the left side panel and with a cold engine take out the four bolts 090 holding the muffler to the manifold flange. Clean the threads up so they turn easy and put two of them back in finger tight. Start it and run it till it starts dying, then turn it off. Loosen the two bolts a few turns, start it, and see if exhaust roars out the gap. Careful - everything will be HOT. Maybe use some sheet metal around it to avoid burning body paint.
Another idea is to take the muffler off and stand a piece of pipe in the hole instead and see if it runs better.
Thanks, I'll try this today.
   / Kubota L3710 runs for 20 minutes then won't run at speed or at all. #20
What in heck is a "rubber oil plug?"
2017 KUBOTA SVL95-2S SKID STEER (A52707)
2017 KUBOTA...
2007 Ford F-450 4x4 Cab and Chassis Truck (A55852)
2007 Ford F-450...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
