Advice, rain down exhaust
/ Advice, rain down exhaust #22
I'm at a loss as to what the issue is?
They're worried about enough water coming down the stack and going through an open exhaust valve into a cylinder. 3" of rain in one cylinder could cause a problem if the engine is cranked since water is not compressible. It might damage something if it's rotated. Similar to a rolled over tractor that has oil in the cylinders.
/ Advice, rain down exhaust #25
Not my tractor so I don't have a dog in this fight... Regardless of the various vertical exhaust pipes some people have...What is the muffler orientation?... The OP has a vertical muffler that the end with a rain bend was off. This allowed 3 inches of rain to enter. I would think any water would then drain through the muffler and into the manifold.
N-C-Jimmy. I suggested turning the engine over by hand. This avoids opening or disturbing the fuel system. Your tractor... Your call...
I popped the muffler off and looked around. Seemed mostly dry. Put it back on and cranked the engine a little by hand. Fired it up, it spat a few black flecks out then idled nicely. All appears fine. Warmed it up then got it under cover. Seems like a non issue now.
/ Advice, rain down exhaust #27
My YM2310 has a compression release which I use when starting because the manual says to. If there was a lot of water or oil in the cylinders would the small amount the exhaust valves are held open really be enough to prevent bending a rod when turned over with the starter? Though I have never hydrolocked my engine it would be nice to know that just pulling the compression release is enough to safely turn the engine over.
Thanks,
Eric
/ Advice, rain down exhaust #28
Not to be a poop, but if an exhaust valve was open, of course it would be mostly dry because it would have drained down into the open cylinder.
Anyway..... glad you got it going with little drama. (y)
/ Advice, rain down exhaust #29
Yes, it's not his tractor and it might be ok.
I don't see how 3" of rain down the muffler hole can get much water past the exhaust valves.
/edit - but then it's not my tractor either
One of my M9's sat out in a monsoon, didn't even think about it, just fired it up and blew black wet soot all over the hood.
New/Unused Landhonor Quick Attach Power Rake (A61166)
New/Unused...
New Holland Workmaster 25S Tractor/Mower (A61166)
New Holland...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
(2) 9.5-24 TIRES W/8 LUG RIMS (A62130)
(2) 9.5-24 TIRES...
2008 International 4300 Altec LRV60-E70 70ft Forestry Bucket Truck (A61568)
2008 International...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A61568)
2013 Mack CXU613...
