B7800 - intermittent power loss/low idle to stop
   / B7800 - intermittent power loss/low idle to stop #1
Sniggle
Jefferson County, WV
2003 Kubota B7800 (new to me @ 435 hours
I have had this happen a few times, to include about 1 hour ago. I was back blading the riding ring, and about 1 hour into the job the tractors idle dropped to almost nothing, it sputtered for a bit, and then died. I tried to restart a few times, and it would not get going. I checked all the fluids - good, air filter - good, fuel level - good, fuel filter - good, radiator - could not hear any boiling or see any overflow. After about 10 minutes, I decided to try her again, and she started up fine, finished the back blading, and running the rake over the riding arena...about another 45 minutes of work.
I, at present, do not have any of the gauges or lights working (except the tac), thanks to a mouse this winter. Fuel is new, fuel filter is from last year.
Any ideas on what is going on? Thanks!
   / B7800 - intermittent power loss/low idle to stop #2
Loosen the fuel cap an see if that cures it. The vent might be blocked.
   / B7800 - intermittent power loss/low idle to stop #3
I'm no expert, but it kind of sounds like it slowly was losing its fuel source.
if loosening the fuel cap as suggested above doesn't do anything the next time it starts sputtering, I'd put in a new fuel filter, even if the old one visibly looks good. Nothing really to lose with a new filter anyway.
  • Good Post
Reactions: JWR
   / B7800 - intermittent power loss/low idle to stop #4
Other things to check / do are :
Confirm that the lift pump is working.
Blow low pressure compressed air back through the fuel lines to the tank.
Confirm the the tank and separator are not contaminated with water.
   / B7800 - intermittent power loss/low idle to stop #5
I was going to ask how the OP determined his fuel filter was good.
Years ago I had a different, but similar, issue on my B2910, which is the same tractor as the B7800 with some deluxe features.Turned out it was caused by the fuel filter.
Changing the fuel filter is a good idea, unless perhaps if physical fuel flow has been verified through the filter. I would change the filter anyway. Not very expensive and easy to do.
edit: Pretty sure there is no lift pump on my B2910, so probably none on the B7800 either. Don’t see one on the electrical diagram for the B2910.
Thanks for the suggestions. I will swap out the fuel filter, and loosen the fuel cap if and when it next decides to sputter.
I did start it up today without a hitch to throw the belly mower on her. I do need to make time to dig into the instrument cluster and figure out what the mice damaged/destroyed. I did a look around when I removed the mouse nest, and I did not see any wires chewed, but the mouse piss had badly corroded the leads to the box that controls the instrument cluster. I am hoping I can clean it up and get back my gauges and idiot lights.
   / B7800 - intermittent power loss/low idle to stop #7
I am new with my b7800, but I would start with tank drain valve. Any water in fuel, if you remove hose from filter take a sample in clear container.
   / B7800 - intermittent power loss/low idle to stop #8
I was working on my b7800 and found a coiled tube in the engine compartment that attaches to the firewall Tha looks like the breather for the gas tank
   / B7800 - intermittent power loss/low idle to stop #9
I believe the older B Series machines have a mechanical lift pump. Unlikely to be the problem though.
   / B7800 - intermittent power loss/low idle to stop #10
I think you are right. Time to pull out the workshop manual and verify at my end!
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2012 Ford F-550 Crew Cab SWAT Transport Truck (A55852)
2012 Ford F-550...
