Jimna 354
/ Jimna 354 #1
Rob Larson
Jimna 354
My Jimna 354 Turns over But will not start. Fuel to injection pump but no fuel at injectors
/ Jimna 354 #2
Have you checked the oil level in the injection pump? Sounds like it is air bound, did you run out of fuel? You'll need to loosen the hard lines at the injectors and crank it over with the throttle set to low idle. As fuel begins to squirt from the lines, tighten the line nut after all the air bubbles are gone. This is all based on the assumption that you don't have collapsed flexible fuel lines.
/ Jimna 354 #4
If you ran out of fuel you have to prime the fuel pump. On the pump there is a small hand pump. You unscrew the top to release the plunger, pump it until you hear fuel running back into the fuel tank.
2016 International DuraStar 4300 Dump Truck (A64556)
2016 International...
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
6ft. Telehandler Forks (A65640)
6ft. Telehandler...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
