New L3901 with HST stop going forward or backward
   / New L3901 with HST stop going forward or backward #1
CindyCRNA
Member
Near Kansas City Kansas
L3901 HST
Our tractor has 50 hours on it. My husband (!) was mowing a bumpy rough patch that I mowed last year and while he was mowing, the tractor stopped. The PTO was running fine as he was mowing and the tractor just stopped. Engine running fine, PTO running fine. No forward or backwards. We leave it in 4WD so I'm going to run out and make sure nothing got jostled out of position. My first thought is maybe the lever jumped out of the 4WD position and was in between the 2WD and 4Wd position. What else should I look for?
   / New L3901 with HST stop going forward or backward #2
Make sure the low/medium/high lever didn’t get jostled into the neutral that’s in between them.
left side down by your leg/hip area
   / New L3901 with HST stop going forward or backward #3
^^^ that above... I assume the engine does nothing when you try to move... (bog down)
   / New L3901 with HST stop going forward or backward #4
The HST forward / reverse solenoid is under the tractor.
Before I armored underneath with expanded steel, brush swept off the solenoid wires twice.
   / New L3901 with HST stop going forward or backward #7
I love an easy fix! The HST had been bumped into neutral.
I have some bumpy spots in my fields also…….tell the old man to slow down!!!:)
   / New L3901 with HST stop going forward or backward #9
Economy Ls have a manual linkage for the HST. Only the fancier Grand Ls have electronic go pedals & servos.
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
1611 (A57192)
1611 (A57192)
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2015 VOLVO VNL760 SLEEPER (A57880)
2015 VOLVO VNL760...
