If You Were To Get A New 6 Ft Finish Mower - What Would You get?
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #21
Everybody talking about how fast they can mow. I didn't move to the country and buy a bunch of land to spend as little time as possible out on it. I put on my noise canceling headphones and some music and I can stay out there all day. It reminds me of golfers who brag about how fast they can play 18 holes. And if I ever decide I don't have time to mow it, I'll just let it grow.
I hear you. With kids, sports, school, and work it is a juggling act. Once the mowing is done, I can get onto the stuff I really want to do on the property :)
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #22
I mow 7 acres. In the summer it can be every 4 days or so. It took me 4.5 hours with my JD x758 tractor with 60" deck. With my zero turn I can get it done in 3 hours. I love mowing, but I have a lot of other fun things to do in the summer so reducing mowing time a little is important to me. If mowing was my only 'hobby' I'm sure I'd think differently. In MN we don't get a lot of summer though...
And no, I don't mow at 13mph really. That was sarcasm because this thread is primarily about rear finish mowers on a CUT, which are WAY slower.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #23
I enjoy my two hours mowing - this time of year. When things dry out - not so much fun. Like playing with go-carts in a dust bowl.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #25
How much gas do you use mowing 7 acres? My zero turn uses a lot more fuel to mow the same area as my tractor does. The tractor is diesel.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #26
Yes. But does your bank account want one?
that is the problem :)
does anybody here have a DIXIE CHOPPER ? I saw them featured on Orange County Choppers one time and loved it.
there are a few zero turns that grab my attention, but my Land Pride mower deck is fine, does the job
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #27
I use my JD 570 to mow my "lawns". I have two acres of lawn. If I traveled much over 3-4 mph - a seat belt would not keep me on the mower. About 80% of my "lawns" are mowed field grass. And with all the associated bumps, dips, ruts - etc.
It takes me a full two hours to mow my two acres of lawns.
Yep. My “lawns” were all woods and cow pasture a few years ago. They would beat me and the mower to death if I tried to race around.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #28
I have the Landpride 5 ft rear discharge mower. I bought it new I 2004, and it is still giving a nice cut with no clumping of the cut grass.
I don’t let my grass get much over 6 inches, so that probably factors in the results.
Overall, I am a big fan of Landpride products.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #29
Why?
Let 5 of it go back to rough(er).
I too mow about 7 acres closest to the house. Why? Rattlesnakes and fires. We like to walk on the property with the pugs without stepping on a snake (which like to hang out in the tall grass). I also want to drive anywhere on my property without setting it on fire. If there is a fire, there is no fire department to get here before the house goes up in flames.
I only have to mow a few times in the spring. Mowing season is pretty much over here in May, so fuel used to mow isn't a real concern.
Your mileage may vary...
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #30
Well, I would not get a damn 4' wide finish mower to mow the acres my family cuts... It works, but it's too small. I can whip around on the 8N with it, and get a pretty good job done on the "lawn" acres in 2 or 3 hours. When I run the same area with the Walker with the 42" deck, it takes way longer, but the trimming is done tight. Of course, the Walker beats me up with no suspension, and a lot of rougher ground.
Going to look at a JD 272 later today. At least that puts me at a 6' cut. It's a stopgap as I'm still working on getting my 6' finish flail going.
It's almost like my father and uncle just wanted to spend as much time as possible cutting grass... I like the grass cut, and I'll be cutting just as much, but the equipment is for sure going to get bigger/faster, and anything I need to do fussy trimming around is going to get simplified somehow... There's way too many other things I would like to be able to do than just cutting grass. (and yes, I love seat time, but I can be in the seat doing other things too.)
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #31
I can't really say for sure. I bought it last year and it was such a dry/odd weather pattern that I ended up only mowing about 2/3 of the property and the rest was not 'normal' mowing' so I never paid attention to the stats. I'll figure it out this year if the weather is more normal.
My x758 is a diesel and would take about 4.0 gal to mow 7 acres in 4.5 hours. Roughly 0.9 gal/hr to run that. I know the Rogue will use more per hour since it is gasoline and a larger engine. But it also only takes 3 hours to mow because of the speed and larger deck (72" vs 60") so ultimately the quantity/cost of fuel per mowing may well be better than with the x758. Time will tell. The suspension and shorter mow times sure are nice compared the the x758 though.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #32
I don’t disagree with you, which is why I bought the zero turn, but it uses most of it’s 5.6 gallon capacity to mow 3 acres. I haven’t measured precisely but I have to switch tanks to get it done. I can cut the whole thing with my tractor and barely move the gauge on the 8 gallon diesel tank.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #33
I mow 5 acres (used to be 10) of grass with a finish mower. If you're pulling the mower with your 3038E, I'd suggest getting the 7' wide Phoenix mower. Your 3038 can handle it. Rear discharge, very few clumps, but depends how long you let the grass get before mowing. The more length you cut, the higher the probability of clumping, as well as mowing with dew still present.
It also depends on how rough your ground is. Today I mowed the 5 acres with my neighbor's zero turn. Was thinking of getting one, but wanted to try one before I bought one. My "lawn" is more like pasture topography. Not smooth at all. The zero turn beat the snot out of me. I'll take my tractor and the 7' finish mower any day over the zero turn.
My 2¢.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #34
I had a 5' Woods finish mower and thought about going bigger. It cut fine but was slow and left me with a need to trim. Got a Ferris 3200 61" ZT and cut the mowing/trimming time down from 5+ hours to < 2 hours with no trimming. It has a full coil-over suspension so they aren't as bouncy and jarring as others I test drove. Was cutting at about 3mph and now closer to 10+mph and don't need to slow down except for the turns and can zip around everything with ease. I didn't want two items to maintain but needed to find more time each week with work/kids and was the biggest bang for the buck. The Woods was a nice mower. I would have preferred one with better wheels/rollers if I was getting another to help avoid scalping.
I had one of these and found it to be a POS. Cheap plastic or no bearings at all, light duty deck, crappy wheels, gear box failed within 5 years. The landpride replacement is built like a tank in comparison, still going 30 years on.
I'd get a rear discharge finishing mower that has 4 run flat wheels you can just drop on the ground and go, greasable everything with zerks that can be accessed without removing safety covers, bearings in the wheels, easy clean fabricated deck (not stamped) that doesn't hoard grass clippings, beefy spindles. Rounded front corners on the deck to slide past trees instead of sharp corners that tear off bark and get caught on rocks and fence posts.
Probably not what you were looking for, but this is my 6' finish mower.
I can mow at 13 mph, so there's that... :)
Nice if I could afford it!
I had a thread here about restoring some old finish mowers. One was a Befco 7' Rear Discharge that was built like a tank. Another was a Modern Manufacturing 6' Rear Discharge. As far as I can tell, it's identical to the one Northern Tool sells: NorTrac 3-Pt. PTO Finish Mower 72in. Cutting Width | Northern Tool
Everything looks identical and I was able to get new blades from Northern. I think they make them for Northern. I can't say it was as stout as the Befco, but it seemed reasonably solid. I have a belly mower and really don't have terrain suited for a rear mount, plus I'm not sure my machine could have powered it. Sold it for $800, in OK shape, but not super great.
Not sure if that has the same chute type discharge you were mentioning, but it's nearly full width and has chains.
I can't mow fast. Too rough and too many hills and turns.
Yea, that norther tool one has the same chute mine Muratori has. Nice but if the grass is not pretty short it does clump some. The chains make it worse.
Good mower but for this I am looking for a different rear discharge.
My 2¢.
That is one reason I am staying away from the Z turn. Too rough.
I'd go 7 foot but it won't fit on my trailer!
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #38
Bush Hog, 72" rear discharge finishing mower; RDTH72 - one of the most used (hour wise) attachment I have. Also one of the best built (like a tank and no rust). Bought it used for $750 and one of the better "buys" for my implement list....
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #39
Normally use a 46” riding mower
I’ve borrowed my neighbors Kubota L3010 with a 84 woods finish mower……huge timesaver!!!
He has a second 84” woods mower I’m gonna test on my L2501 this weekend…….if it works I may buy it!
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #40
I know some on here will bash this, but here goes.......
I purchased one of the 72" mowers 2 years ago and haven't had one problem with it. They have a sale on now with an additional 5 or 10% off.....
They also stock parts. Free delivery to your door. I know people that have one their backhoes, flail mowers, and chippers. No complaints from any of them.
Considering that they are almost half the cost.... well if it wears out (IF)... you can still buy a second one and be ahead of the game. My neighbor saw how well my mower cut and ordered a 60" for his tractor.
I have used and abused this mower, including using it like a rotary brush cutter.... abuse included cutting 12-16" yuccas out in the fields. The discharge is across the entire back, spreads the clippings very uniformly.
You have to make the choice however.... this is only a suggestion.
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
