so right now so far what i have accomplished is putting a new pump and filter on, made sure vent line was clean...ran it for about an hour then it stopped, i took the cover off and watched the filter after i got started back up it would run, then the filter would go dry and die....so i took it back home took the tank off last night, emptied tank checked for trash didnt really notice any, pulled to fuel supply line out, the internal line may have been too long it did have a small kink in it, i cut that off, tried to blow through it and barely could, so i hooked air hose up and blew some what looked like dirt out of the hose, also blew the line out from tank to fuel pump....i think i need to blow the line from pump to carb out....once i hooked back up and turned key on fuel would just barely trickle into the filter...i may need to get another plastic tube for tank idk...i dont think its gonna work just trickling out of the tank to the pump....
