What happens??
/ What happens?? #1
LD48750
SE, MI
Ford 1510 Mahindra 1526
What happens when you put a 5/8" belt on/in a 1/2" pulley?
Electric PTO clutch running a Mid Mount Mower.
/ What happens?? #3
1/16th hangs over each side. Will it rub anything? Is it the same type of belt? Same lenght? Just 1/8" too wide?
/ What happens??
Nothing that I can see. Same old belt, new clutch & pulley.
It may cause the entire tractor explodes into 10,000 pieces killing everyone within 100 feet. Other than that, it may wear out a little quicker and not be able to transmit as much torque because of the reduced contact area between belt and pulley.
If that happens, I guess I'll have nothing to worry about.
/ What happens?? #5
You should be fine.
/ What happens?? #6
Trying to logistically think thru the question. Two things come to mind.
1. It may try to come off.
2. It may slip because of less friction.
/ What happens?? #7
I did that once and the belt looked like
confetti all shredded to crap. The belt
should always be just slightly inside the
outside edges of the pulley unless you
like buying and replacing belts
willy
/ What happens??
willy
Thats not what I wanted to hear.
Now when the new clutch gets here I'm going to have to see if I can exchange it.
Thanks for the info before I make the new part un-returnable.
/ What happens?? #9
Not sure how logistics figures into this equation.
Use the belt and let us know how it works. I think it will be fine.
/ What happens?? #10
Ummmmm,,,,, logistics as in the compatibility of two physical objects. The same logistical thought used to determine that a larger belt is needed in a specific application. Or a smaller belt needed in a different application.
If there were no logistical thought used all belts would be the same size.
Maybe we have differing definitions of logistics? :)
/ What happens?? #11
I think of logistics as the path something takes to get from point A to point B in the supply chain. I would have used logical instead of logistics in your sentence.
/ What happens?? #12
I think of logistics as all physical action and assets used to accomplish a task.
/ What happens??
Clutch got here & belt fits fine.
Might have it on this weekend.
Right now, everything looks good.
/ What happens?? #15
I'm all for 'try it and see', but something noone mentioned yet is that a belt that rides up higher in the pulley sheaves would need to be longer as well, unless the tensioner mechanism had the extra travel to accommodate the change. Which it probably does. Carry on. :)
/ What happens?? #16
Thanks for the update. Report the result. Thanks.
/ What happens?? #17
In my case it only took a few minutes to turn
the belt into confetti and at $$$ a pop not a
very good idea. I got the larger belt thinking
larger better will last longer? I put the belt on
a lawn mower deck John Deere to be exact.
willy
/ What happens?? #18
willy
I've tried running wrong sized belts. Some larger. Some smaller. I never had long term good results. :(
/ What happens?? #19
I had to take a class module on belts about 5 years ago. It was pretty interesting. Don't remember most of it now, as all of the things I have with belts at my job are documented on the machines and we keep spares hanging right there next to them. If you get down to one spare left, you order another.
What's kind of interesting is I may have 5-6 identical units, but they'll take different belt lengths. I usually think to myself, why? Don't they make them all on the same assembly line, and isn't the tensioning mechanism the same? I don't get it. But, I'm not paid to get it. Just order, replace as necessary. šŸ™ƒ
/ What happens??
Mine is also for a mower deck but it sure looks like it fits.
Other pto clutches by this manufacturer are listed as 1/2" / 5/8" so I am hoping this is the same pulley.
We'll see this weekend maybe.
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2013 John Deere 1790 Planter (A63109)
2013 John Deere...
Polaris Ranger 400 H.O. (A61166)
Polaris Ranger 400...
2023 John Deere 2100 Ripper (A63109)
2023 John Deere...
2013 BMW 528I Sedan (A61569)
2013 BMW 528I...
