My bucket is broken !
/ My bucket is broken ! #41
As a lifetime but now retired welder that small mig will do the job. 2 things help if welding say the ends back on the bucket. 1st is the mig gas. Use 75/25 as it burns hotter than straight CO2 plus less splatter. And 2nd weld vertical as much as possible as it allows you to see the weld better and wet it in plus multi pass vertical is pretty.. Never used fluxcore on a small mig so no real insight into it but I do not think I would be a big fan. If needed I would just stick weld it. Also cleanliness is next to Godliness in mig welding. No rust or paint, clean shiny metal
The issue with small MIG (low output welders is), most will only run flux core. They don't come set up for shielding gas.
/ My bucket is broken ! #42
Typical thread on here, I'd say. (y)
Gonna be more than motor work on that slug. I bet the generator head has lost it's magnetism and the electronics are shot too.
There is only one way to find out, though it won't be today. 😂
/ My bucket is broken ! #43
Just a caution to those who have never welded but want to try...
it can get addictive.
I haven't even made it to the novice stage but there's something satisfying about taking two pieces of steel and making them into something useable. If you work something too hard or it's just getting tired, take it down to the shop and you can be up and running again in an hour. I have two AC Lincoln welders which were hand me downs from my father... one is an old "Tombstone" which I was getting proficient with until I moved and didn't have a place to plug it in. It's probably older than I am but still does all that I need it to do. The other was his "WeldanPower" which is a light AC welder generator. I'm not a fabricator or high tech welder, but he built more with those two machines than I ever will so they are good enough for my uses.
/ My bucket is broken ! #44
And will last forever with minimal care. Lincoln builds a quality product. You pay for it however. Been to their Euclid, Ohio facility numerous times and been in their first article destructive testing facility attached to the plant. There they literally run all the engine drives to death, impose 100% cyclic loads and monitor fuel consumption as well as longevity. There are staff that keep the oil and filters changed on the recommended maintenance schedule but they run them at rated output (except for downtime service) until something fails on the engine or the welding head. Lots of resistor banks and fuel storage tanks outside. I have noticed they don't use the gas/diesel tanks at all but hook them to their bulk supply.
When they run to failure, the units are disassembled in their QC lab and analyzed for component failure and those components are ungraded as needed. Very impressive (and noisy). Last time I was there, they were destructive testing a couple Pipeliner units and some Weld and Power units, all at full rated load of course.
/ My bucket is broken ! #45
Welding any metal parts together and have them actually be 'welded' to each other is 95% prep and 4% weld technique and 1% machine.
Poor prep equals a poor job.
/ My bucket is broken ! #46
I dubbed around for decades and was bad on a good day. Then I took a course at a tech school and an hour later I was better than I ever was. When the course was over I was running beads that were strong and looked better than what I saw other guys do. I learned gas, flux, stick, and TIG, but I'm a little shaky on TIG. It is among the best money I have ever spent. Take a tech school course.
/ My bucket is broken ! #47
If you can gas weld, you can TIG weld. Not much difference except the heat source. Playing a guitar or piano is also similar.
/ My bucket is broken ! #48
Yes, but what about playing guitar on a piano?
/ My bucket is broken ! #51
There was a time when I was really getting down on my guitar then the crank came loose and things haven't been the same since.
Now that i think about it,cranks seem to be my downfall. I've twisted the crank on my welder first one way then the other and all I succeed in doing is making smoke and sparks,not counting the time I set some dead grass on fire.
/ My bucket is broken ! #52
No cranks here, just knobs and digital readouts. I do prefer twisting knobs over cranks anyway. Especially with those knobs are attached to something I cannot mention on here.... :rolleyes:
/ My bucket is broken ! #54
Yes I think so, I wished I could weld. Most welder down here want an arm and leg to fix it.
Don
I hate those lazy weld shops that wont spend an hour cleaning away dirt and paint and re-weld something in an awkward position for me for only $5.00
Expecting me to pay more than $5 for a little piece of wire? WTF
/ My bucket is broken ! #55
Did someone put orange juice in your coffee this morning? 😂
/ My bucket is broken ! #56
Time
Don
Time to bite the bullet and have it welded...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A64557)
2008 21 Ft...
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
1997 LEDWELL 48FT DOVETAIL TRAILER (A65643)
1997 LEDWELL 48FT...
