My bucket is broken !
/ My bucket is broken ! #2
I don't believe you will find Vtek parts, at least not here in the U.S.. They were specific to Vietnam reconditioned tractors and I have never seen factory parts support for them. If you can't repair the old one your best bet is to find an appropriate size bucket and adapt it or do what I ended up doing for my FEL ( not a Vtek), fabricate a bucket.
You say the bucket is broken, can it not be repaired?
Yes I think so, I wished I could weld. Most welder down here want an arm and leg to fix it.
Don
/ My bucket is broken ! #7
I build my entire loader, subframe and bucket with a little 110V Lincoln Weldpack welder 14 years ago. It is strong enough to easily lift the back end of my tractor off the ground with 800lbs of counter weight hanging off the three point hitch. I have yet to have a weld break. That Harbor Freight mig welder will be plenty to repair the metal on a Vtec bucket if you take your time and prepare your material. Youtube and a little practice will get you where you need to go on this project.
/ My bucket is broken ! #9
Don
What's broken? Where? Something seriously bent out of alignment? Piece of 1/8in plate or a 1/4in thick gusset? Crack or broken previous weld?
Got a Pic or better description of the problem available? Don't want to put the welding cart, full or undersized, before the horse so to speak. Sounds like you might have already got an estimate to repair and it's a tad more complicated than a cracked existing weld?
Or not?
/ My bucket is broken ! #10
Without a picture of the issue, your comment is worthless. Far as the cheapo HF welder, it's flux core and will make a mess of any weld you attempt.
I rebuild buckets for those less fortunate and it takes way more than a 200 buck welder.
/ My bucket is broken ! #11
Don
How much is "an arm and a leg" down there? A newish bucket will be hard to find, expensive and hard to ship. Fix it, would be my advice.
/ My bucket is broken ! #12
If I were going to buy a welder I would personally get a HOBART HANDLER 210MPV... Yes expensive but able to handle most farm/ranch jobs for the "hobby" welder...
Expensive yes but probably the least expensive in field of better welders.... Buy once, cry once, be happy for along time....
The $200 FCAW welder from HF is a joke for the uneducated beginning welder...
/ My bucket is broken ! #13
I actually run 2 of them in a limited production setting and have for years. Only downside is they are incapable of running 50 pound spools, 10 pound maximum. Far as I'm concerned, best glue gun for the price point made. Even in a limited production setting, neither one has ever exceeded the duty cycle and they have enough output to do spray transfer. Both on 230 /1 btw.
/ My bucket is broken ! #17
Call some of the welding schools around you. Chances are you can find one that will let a student weld the bucket. It's also a good teaching opportunity for the school. A buddy of mine who runs a couple welding schools usually doesn't charge if the "customer" buys some beer for the students.
/ My bucket is broken ! #19
respectfully disagree, the cheap inverter welders will weld, that is a fact.
/ My bucket is broken ! #20
Whatever. I do it for as an additional farm income. I never said they won't weld, hell you can stick weld with a car battery if you are inclined. What I meant was, the cheap welders don't have sufficient output to weld heavy gage metal. Nothing more.
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
Informational Lot - Financing (A63689)
Informational Lot...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
7' Road Blade (A62613)
Hedge Posts (A65640)
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
