Ford 4000 lift arm end adjustments
   / Ford 4000 lift arm end adjustments #1
oldbeagle
Durham, NC
Ford 4000 and MF275
working on a 4000 series tractor that has a feature I've not seen before. The ends of the lift arms where the balls go into where you attach your implement, seem to be able to extend out about 10 inches. Seems someone welded them in retracted mode, but the weld on the left one broke, so now it's in extended mode. If I push the end back into the lift arm ( retracted mode) there's nothing to hold it in place and extends back out by itself. Is there a part missing or something to allow them to hold their retracted/extended positions?
   / Ford 4000 lift arm end adjustments #2
I'm guessing someone swapped your lower arms with telescoping ones from a 3630 or some such. Parts (retaining pins, etc.) should be available at a good tractor supply. Good luck.
Jim
   / Ford 4000 lift arm end adjustments #3
I'm assuming you have a 65-75 3 cylinder 4000. You should always mention that or include it in your profile.
10 inches seems like an awful lot. 4-5 is the norm unless you have something I haven't seen before.
They are a Very handy feature when hooking up to a heavy impliment.
Hard to believe someone would weld them shut.
Parts for them are still available from New Holland. I would fix it.
   / Ford 4000 lift arm end adjustments #4
How does one extend these
   / Ford 4000 lift arm end adjustments #5
It is possible the ends are OEM or aftermarket. We do not know how they work unless we know what you have. That is why pictures are important.
   / Ford 4000 lift arm end adjustments #6
I can get pictures but they look like the ones above but without the hump on top just a hole and I piece of cable in the hole
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
Terms and Conditions (A47384)
Terms and...
