Mahindra 2810 run away
   / Mahindra 2810 run away #1
Raisinman
Mahindra 2810 classic
I have a Mahindra 2810 classic. The fuel tank was left completely full and burst the filler neck off, i know some water got into the system. Drained completely and replaced fuel and filter but engine still runs away. Only way to stip it is disconnect fuel line. Neither the key switch or pull out knob will stop the engine. Ideas please??
   / Mahindra 2810 run away #2
I have that same tractor and it has been a great machine, Maybe check the throttle and make sure it is not stuck in full . Mine has got real hard to move before and i had to lube the cable.
   / Mahindra 2810 run away #3
Yup, it’s either the throttle cable OR the injection pump control rack is stuck..
I’m not familiar with your machine but if u can remove a plate to gain access to the side of the inj pump, I think you’ll find the problem if you push/pull on the throttle WHILE LOOKING at the PUMP RACK..
Throttle moves freely. I took the shutoff lever off the side and the part of the injector pump that looks like a barrel latch is completely frozen. So i'm thinking pull the injector pump out and soak it with the waterand gunk ive seen so far i'm betting the pump is either rusted or gummed up almost completely.
This is the fuel filter i pulled outof it
   / Mahindra 2810 run away #6
Lol.. so u know what the inside of the pump looks like..
Whatever you do, don’t hammer on the control rack..
If you’d like some experienced hands on it, I’m available..
   / Mahindra 2810 run away #8
Typical Bio Fuel after it sits..
They autta make that a “sticky” .. lol
Pulled the injector pump and soaked overnight. Got the shut off sliding freely, all good now. Starts right up and idles good no smoke!
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
2012 Chevrolet Tahoe LS SUV (A48082)
2012 Chevrolet...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
