What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,242
That's damn cool.
Thanks. We often need to get a little elevation for roof-raking snow or beating off some ice dams on the eves or a thousand and one other small chores that crop up. This is much easier and safer than trying to work off a ladder.
   / What did you do on or to your LS Tractor today? #2,243
It certainly gives me a few ideas, maybe one day I'll put them into action. Solid inspiration. 👍
   / What did you do on or to your LS Tractor today? #2,244
It took about 15 minutes to cut out the door with the sawsall, 10 minutes to smooth all the cut edges and 10 minutes to find and install the safety chain. I still need to add plywood in the bottom and a chain to attach to the fork frame. Simple and Quick.
For the worry warts...I plan on building various lengths of hydraulic cylinder safety stops for added safety (in case a hose should blow or a hydraulic seal should fail).
   / What did you do on or to your LS Tractor today? #2,245
Got a bit of seat time yesterday. Clearing part of our place that’s been overgrown by kudzu, briars, brush and trees.
   / What did you do on or to your LS Tractor today? #2,246
A few more pics.
   / What did you do on or to your LS Tractor today? #2,248
Looks very nice ! might try something like that myself someday
   / What did you do on or to your LS Tractor today? #2,249
Nice job. A little bit of seat time can make a huge difference in aesthetics.
Thanks, trying to get ahead of the kudzu so maybe I can keep it cut. When that stuff greens up the vines are like cables and will wrap around axel shafts, choke the cutter down, even saw it wrapped around the driveshaft of a power co. truck and immobilize it. The crew had to take an axe to cut it off the driveshaft.
   / What did you do on or to your LS Tractor today? #2,250
I reworked an IBC Tote and made a Man Basket (for the Wife) to use with the forks.
We did the same, I added a rubber stall mat cut to size from TSC to the floor, it made a huge positive difference in foot stability and tool retention.
2012 BMW 328i Coupe (A55853)
2012 BMW 328i...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2013 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52706)
2013 GENIE...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
Plasmarc PM150 Plasma Cutter (A54811)
Plasmarc PM150...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
