I did it. Roast and discuss my choice. (sharing experience + numbers for others)
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #41
As far as blower, I need to do more research, but I have been looking at the Erskine 925RM. It's 3 point 90inch width, 35inch height, 540pto. I figure something that size will clear my driveway and turnaround in no time.
I am looking for a bush hog as well to help cut the pasture as I am not having any livestock out there this year as I am moving the fence etc to put in trees and build the shop.
I purchased a 4707 in late December, blew a little snow with it (we had very little here in SD this winter). I have a Farm King 960 on it, and its too big for the tractor IMO. Any drift and it pulls the rpm down in a big hurry, and you have to ride the clutch, which is extremely grabby. I'm really unhappy with how grabby the clutch is. It makes loader work and blowing snow very difficult. A creeper gear for blowing snow on a lower HP tractor like this would be ideal.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #42
goridedoo is very correct about creeper gears. On a smaller tractor with a 5ft blower I have found over the years that lesser snow depths (say under a foot) are easily handled at 'normal' tractor reverse speeds. However deep stuff or especially heavy packed snow bogs you down in a hurry. My older Kubota happens to have a creeper gear and that turns out to be ideal for snow blowing. You should have a low enough gear on the 4707 I would think to maintain good progress even in deep/heavy snow, especially with the PTO hp you have. The goridedoo user though has the specific experience using a 4707 and you see what he says. That Farm King 960 is an 8 ft blower with dual augers. I have zero experience with dual auger blowers which I thought were sold primarily for the really DEEP deep stuff.
Maybe someone on here knows if dual auger blowers are harder or easier to drive through snow than single auger. I really do not understand why a 8ft blower is too big for the 4707 but then goridedoo has the experience. You sure do not want to be riding a clutch !!
I think these concerns are partially why I am going to order the snowblower through my local MF dealer. They are close so hopefully any "break in" issues I encounter they can help me fix without too much pain. But for the snowblower I figure if anyone knows whats an appropriate size for the 4707 it should be them.
Do you do this in order to reduce your ground speed? I'm imagining that the snowblower starts to plow snow if you're moving too fast for it to process and could potentially be bad for the unit unless you slow down and let it catch back up. Do you know what transmission you have?
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #44
Correct. I have the Dyna 2. Hard wind blown snow is what I was running into issues with, which we have a lot of here. I think if you tried to blow through a lengthy 1ft hard drift without being on and off the clutch you would kill the tractor (with an 8ft blower). Not trying to discourage you, but my 4707 is a dog with that blower on it.
I posted awhile back in the snowblowing section to see if anyone thought a 7ft single auger blower would be better, but didn't come up with much.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #45
I do not have a snowblower in use on my larger tractor. Just drastically less snow where I am even in the WV hills compared to you guys. I would comment that you want a blower wider than your wheels and you can probably cope with whatever other issues there are with width. Surely the low-low gear on 4707 would be OK and let you avoid excessive clutch use in all but the worst cases. There are so many techniques too -- like multiple passes if the snow is too deep/hard, cutting less than a full width path if loading is too high, etc. On a tractor that size I cannot see going with anything less than a 7 ft blower. Again, your tire spacing is probably a good reference point.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #46
I have a 6' blower on my 50HP tractor. A creeper gear would be great. It's not about engine bogging down, but if snow is heavy and deep it can pack into the blower, may break shear pin and require clearing out by hand. Worst situation is first pass into the snow berm at the street from county plows which pack the snow in as they move it. So I usually just use the bucket there or take smaller digs into the berm going back and forth.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #47
Lots of variables. I think my machine would work fine in 10-12" of light to medium density snow that fell straight down. That just doesn't happen here, we'll get 6", and 50mph wind for two days. Makes for 3-4ft drifts that are so hard you could drive right over the top of them. That first cut can be tough! I agree though, would still want a minimum 7ft blower.
I have intentions of tuning my tractor to 100hp or so, once my year of warranty is up. Could have bought a 4710, but I believe it was about a 10k upgrade, and the added hassle of DEF.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #48
Nice Tractor just know that you will really
enjoy the cab when blowing snow!
Do you have snow fences up along side of
your drive way??? They really help. You
could even put them in two rows if the snow
is too much!
willy
Looking at the specifications of the Farm King 960, they want a tractor hp of 90-125. So you are correct saying its a little too large for the 4707. I have been eyeing that Erskine 925RM, single
auger, 90" width, 35" cut height.
Just kidding, I'll probably be right behind you a few years down the road. Who knows what will happen though.
your drive way?
I do not. I learned all about them this winter though thats for sure. I will put them up for next year and see what kind of difference they make for me.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #50
You can certainly have some chips changed and do things for your 4707 that will give you more HP. My guess is, though, that traction will be your issue rather than horsepower. An 8ft blower trying to push heavy windpacked snow at more than a creeper speed is going to cause you to lose traction, I think. Don't you have that problem ?
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #51
I do. Look at the HP numbers required for that blower. What I don't understand is why the poster didn't consider that before purchasing it.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #52
Again dependent on alot of things. The one storm we had this year HP became an issue before traction. I had a 1086 on this blower before, 130 pto hp, and traction was always an issue. HP could be an issue in heavy snow too believe it or not, but low-low in that tractor is just way too fast for blowing snow.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #53
If you're referring to me, see the above post. I previously had the blower on a 1086, and decided I'd try the blower on the 4707 before trying to sell it.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #54
As title suggests, I did it. I bought a tractor and paid far more money than I ever thought I would for something that isn't real estate. After many hours of reading, test driving, calling, and spitballing on what I should get I landed on the Massey 4707.
MF 4707
Cab
dyna 2
931 loader with soft drive
4x4
30 inch rears
60k even, delivered.
For reference, my main goal with this is to put a massive snowblower on the back and keep my driveway clear. I have a 500ft drive and the drifts are terrible where I am at. Secondary goals are driveway maintenance, pasture fence maintenance/moving, and managing 30 acres of pasture. I currently rent out my crop land but that might change in the future. Potentially could get into making hay to sell. Land is fairly level.
I'm a suburban dude who just wants to be comfortable while doing work outside. How did I do for a first time buyer?
From experience of ppl who have bought blowers from the tractor place I work at, with the exception of those who have short runs of say 50 to 100', they didn't mind the rear mounted blower.
The rest eventually regretted their purchase of not getting a front mount blower for the sanctity of the neck.
Your 500' drive warrants a front blower because here's what i've seen happen. "I'm only doing a 200' drive 16' wide. I'll be fine with the rear blower plus it's way cheaper". After two maybe 3 seasons: "I should have listened to you and gotten the front blower but I feel stuck with my purchase of the rear blower and don't want to spring for the front blower".
"Ok" I say back "then my recommendation is to get a 7' or 8' plow while keeping the rear blower but using the plow for the majority of snow removal".
This is a front plow that attaches with quick attach and gives the option of manual configuration or using hydraulics to manipulate the plow. If you are not getting loaded tires, the rear blower will make great ballast for a front plow.
My thinking is for the long game and not the present when you'll be a different person down the line confronting the same problems that are in the present.
Problems don't change but the body seems to. You aren't gonna take my advice of "don't get old" are ya? :)
Good luck w your purchase.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #55
...then you'll agree with me when I say my M9540 (kubota) is hurting for power with my 8' dual auger in much over a foot. I can add a creeper gear to this tractor, but I'm not sure I really need a blower at all and other than blowing snow, I don't need a creeper gear that I believe is around $1000.
Ill say your post made me dig into front mount blowers a lot more than I have previously. It's pretty nutty the options that are available, the prices seem like they are pretty nuts as well. I'm not completely against it, but I think for now the rear mount makes the most sense for me. Forgive me if I'm wrong, but if I was to get stuck for whatever reason, I can use the loader to help push or pull me out a few inches right? That's my primary reason right there, as far as plowing a light snowfall, can I just use the bucket? its 84" should be able to get the long part of the driveway in 1 down and back I think.
Either way, I'm going to keep the front blower in mind. IF on year one if I find myself hating the rear, maybe Ill give the fronts another look.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #57
The closest I ever came to a front blower was when specing out my Kubota L4060 6 years ago. They have a front quick hitch option for a blower, plow, and broom. Unfortunately, the loader has to be removed to use the front hitch, which was a deal breaker for me.
I don't get the same big snows that many here do, maybe a large 2-3' blizzard every 5 years or so. I still cannot mentally be without a loader and bucket option which is the guaranteed tool to handle the biggest storms.
The rear blade / blower and front ssqa plow / loader bucket has worked well for me over the years.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #58
Out of curiosity how do you guys prevent the front plow/blade/bucket from tearing up the asphalt and driveways?
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #59
On the rare occasion I use the bucket, I lay the edge flat then slightly tilt the bucket forward. My bucket has side plates that extend below the bottom of the bucket and they will dig into pavement bad if I don't.
For the ssqa blade, I use a polyethylene UHMW edge that worked great last season. It's 1.25 x 6 x 84. I have a 4 year old polyurethane edge on the rear which will need to be flipped over soon for 4 more years of use.
I plow anywhere from 15-20 driveways from 100' to over 1000'. I got tired of people complaining about barely noticable marks on sealed driveways from the steel edges.
   / I did it. Roast and discuss my choice. (sharing experience + numbers for others) #60
Congratulations on the new tractor. I’m sure you will love it. I live in the upper peninsula of Michigan and have the same problem with drifting. I can get the driveway done and have to start over again! I use a meteor 87 single auger blower with hydraulic rotation and chute. With 85 PTO horsepower I can usually blow the driveway in 540 E. . However, there are times when the drifts are so deep and winds packed that I have to put it in low range first gear 540 regular PTO. Once or twice I haven’t even had to use creeper gear. I say all that to suggest not going overboard on blower width. You’re probably going to have to do two passes on your driveway anyways, down and back, so going a bit narrow will make sure that you stay well within the range of your power and you can use 540 E if you have it. It is nice to have the better fuel economy and lower noise. Also, when I first bought my blower I didn’t get the hydraulic shoot deflection but after one season I added it on. And for all those people that talk about sore backs and necks, I think part of that has to do with how big a cab you have. I have plenty of room to sit comfortably so that I don’t have to stretch my neck too much. After 200 inches of snow this year with lots of drifting and a quarter mile driveway, I have no complaints about a rear mounted blower
2017 Versatille 260 (A60462)
2017 Versatille...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2025 CE SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 CE SB05...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
