Help- 2210 no start
/ Help- 2210 no start #1
T.tractor
2210 compact
I have a problem with my 2210 John Deere compact-it will not start by the key( no click) battery shows over 13 volts/ there is Current to starter. I checked the grounds. Any ideas would be helpful
Thanks
/ Help- 2210 no start #2
I have a 2210. If the engine will not crank, there are two interlocks that will inhibit the starter: The PTO switch and the High/Low/Neutral lever. The PTO button must be in, and the shift lever in neutral. A fault in one of those areas could be your problem.
/ Help- 2210 no start #3
Are you getting activation voltage to the solenoid? If not, Dan's solution is probably the correct one. If you are getting power to the solenoid is it activating?
/ Help- 2210 no start #4
It's a bit disappointing when someone comes along with an issue and then never posts a follow up. It happens all too often.
/ Help- 2210 no start #5
agree.....I stopped responding/trying to help the ones that have just one post. Occasionally they'll come back with a second post, and I'll chime in if I can be of (potential) help.
/ Help- 2210 no start #6
Sometimes the poster has no idea how fast a response can be from TBN. If used to other Forums, may not expect a quick reply.
Also, the poster may not be where the "tractor" is handy to test out the suggestions given. Lots of potential reasons, but this poster did come back on TBN around 5 pm so maybe he will fill us in sometime.
Lets give him the benefit of the doubt. We are not owed anything just because we try to help. IMO
Are you getting activation voltage to the solenoid? If not, Dan's solution is probably the correct one. If you are getting power to the solenoid is it activatinsorry,
Sorry, been working-Yes, have voltage to starter just got done using it (charged the battery and it fired right up)- but for some reason it’s not charging have voltage from the alternator ( it’s not that old) so just kinda stumped didn’t know if a relay would cause it not to charge or if maybe voltage regulator would cause it? Don’t know how to check it
I do have voltage to starter - I charged the battery back up it turns over and runs but it’s not charging the battery. There is voltage from alternator- figure maybe voltage regulator or relay is not working not sure how to check them.. any ideas?
/ Help- 2210 no start #11
What is the voltage from the alternator? Are you using a Volt/Ohm meter to measure?
I will recheck it and let u know- it was a few wks ago when I checked it ( the alternator is only a few months old my father put it on) I believe it was having the same problems then- we use the tractor once in awhile
/ Help- 2210 no start #14
Considering that you have a fairly new alternator, the next thing to check is the regulator. With the alternator unplugged from the regulator, measure the AC volts coming from the alternator with the engine running. You should see something around 20 volts AC. If the regulator is generating good DC power to the battery, then you should see something like 13-14.5 volts DC on the battery. If it's down around 12, then you probably should think about changing the regulator.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
PALLET OF TRUCK PARTS (A60736)
PALLET OF TRUCK...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
72'' Root grapple (A61567)
72'' Root grapple...
2001 Ford F-150 Ext. Cab Pickup Truck (A61568)
2001 Ford F-150...
