How to do it or what is needed
/ How to do it or what is needed #1
Doug-1
Cub Cadet EX 3200
I just bought a small parcel of land (14 acres) that was a corn field in upstate NY. The stalks are still there and there are large ruts where the equipment turn around. How do I convert that to pasture and food plot land? What 3pt attachment would be best?
I have a 32 HP 4wd Cub Cadet EX3200
Thank you in advance for your experience and advice.
/ How to do it or what is needed #2
if you are only using one implement my choice would be a 6' double disc for a 32hp tractor. once it starts to cut you can do a awful lot of work with it.
/ How to do it or what is needed #3
An offset disc will do a better job of cutting up the corn stalks but will now leave as smooth of a field. A tandem or double disc will leave it smoother but will take more more passes to do it. Also, if it is a good quality tandem disc, you will be able to adjust the angle of the gangs, therefore change the aggressiveness of the cut.
/ How to do it or what is needed #4
Cub Cadet Ex3200 Dimensions​
Dimensions
Wheelbase:61 inches
154 cm
Length:109.5 inches
278 cm
Width:59.1 inches
150 cm
Operating weight:2,550 lbs
1156 kg
Ground clearance:10 inches
25 cm
How do I convert fourteen acres to pasture and food plot land?
A 2,550 pound operating weight, 4-WD tractor will barely have enough traction to pull a Tandem Disc Harrow with 18" diameter pans. A 66" wide or 72" wide Box Frame Tandem Disc Harrow with 18" diameter pans will smooth your field but likely require four to six time and fuel consuming passes over the land to do so.
/ How to do it or what is needed #5
An hour with a 5 shank mulch-ripper last fall would have set you up, ready for a field cultivator this spring. But that didn't happen.
Now, it will take your Cub many many hours with a 60" tiller. If it was me, I'd hire it out to a local farmer while the spring field work is happening.
/ How to do it or what is needed #7
Thank you for your recommendations.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Cattle Feeder (A65640)
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2022 EZ-GO ELITE...
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
