What are these brackets on the bottom rung of a stepladder for?
   / What are these brackets on the bottom rung of a stepladder for?
In the photo here, and explained in the questions.
Explained here:
Nick · 6 years ago
What are the 2 metal things on each bottom step for ?
2 metal hook like things on each bottom step .Can they be removed ?
1 answer
Customer Care · 6 years ago
The part that you are referencing is used as a spacer. The purpose of this spacer it to prevent the side rails from slamming into each other.
Bruce
Thank you!
Seems like a pretty lame spacer...
   / What are these brackets on the bottom rung of a stepladder for? #12
Thank you!
Hahaha! I was just thinking the exact same thing after reading the customer care answer!
   / What are these brackets on the bottom rung of a stepladder for? #13
Remember, in this day and age, they need warnings on Tide Pods and McD's coffee. The younger generation will get their finger smashed and call a lawyer :(
   / What are these brackets on the bottom rung of a stepladder for? #14
Na, the younger generation will see a ladder and not know how to open it…. Much less what its used for.
   / What are these brackets on the bottom rung of a stepladder for? #15
   / What are these brackets on the bottom rung of a stepladder for? #16
I believe OSHA only allows 104’ for safety reasons
Must be a new height limitation; I have a 10' (120 inch) one. On the other hand, I rarely use it - it's HEAVY.
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
1274 (A50490)
1274 (A50490)
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
