What are these brackets on the bottom rung of a stepladder for?
   / What are these brackets on the bottom rung of a stepladder for?
In the photo here, and explained in the questions.
Explained here:
Nick · 6 years ago
What are the 2 metal things on each bottom step for ?
2 metal hook like things on each bottom step .Can they be removed ?
1 answer
Customer Care · 6 years ago
The part that you are referencing is used as a spacer. The purpose of this spacer it to prevent the side rails from slamming into each other.
Bruce
Thank you!
Seems like a pretty lame spacer...
   / What are these brackets on the bottom rung of a stepladder for? #12
Thank you!
Hahaha! I was just thinking the exact same thing after reading the customer care answer!
   / What are these brackets on the bottom rung of a stepladder for? #13
Remember, in this day and age, they need warnings on Tide Pods and McD's coffee. The younger generation will get their finger smashed and call a lawyer :(
   / What are these brackets on the bottom rung of a stepladder for? #14
Na, the younger generation will see a ladder and not know how to open it…. Much less what its used for.
   / What are these brackets on the bottom rung of a stepladder for? #15
   / What are these brackets on the bottom rung of a stepladder for? #16
I believe OSHA only allows 104’ for safety reasons
Must be a new height limitation; I have a 10' (120 inch) one. On the other hand, I rarely use it - it's HEAVY.
TEST BID LOT (A50774)
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
Gang Box (A50860)
Gang Box (A50860)
Lot of 3 Dell Laptops (A48083)
Lot of 3 Dell...
