Cylinder Leak Down test?
/ Cylinder Leak Down test? #1
Bedlam
Ford and Kiotie
Hello, I am attempting to probably rebuild the lift and curl cylinders on my Ford 7108 Loader. After viewing a few U Tube vids I had never thought that the leak down (thats slowly gotten worse over the years) could be the control valve . So I found this video of how this woman checks for it.
Anyways I just checked mine this way.
Raised the arms up and supported them. Then removed the quick disconnects. (for the lift cylinders). And then removed the support. It lowered pretty quickly. So I assume it has to be the seals in the cylinders ,as the control is no longer connected to it.
Is this how its normally done?
/ Cylinder Leak Down test? #2
Yes, that's how it's done. It usually is the seals vs the valve.
Here is another way to do it, but it's really overkill.
/ Cylinder Leak Down test? #3
If you are talking about the curl cylinders.....yes.
If you are talking about the lift cylinders.....the main boom will not leak down if the disconnects are unhooked. Oil has to go somewhere. So you either have alot of air in the cylinder or it's leaking oil on the ground
Thanks. yes i checked the lift cylinders but will try the curls next. (disconnecting them) Luckily there are no leaks on the ground..
/ Cylinder Leak Down test? #5
Well you got something else going on as I mentioned.
You can completely remove the piston seals in the lift cylinders and it shouldn't drop a bit with the control valve isolated.
You either have air in the cylinders, leaking oil on the ground you aren't seeing, or you unhooked the wrong disconnects
/ Cylinder Leak Down test? #6
Yup. Also why crossover relief valves don't work on double acting cylinders.
If you don't see oil coming out, it's either air or a leaky valve.
You can completely remove the piston seals in the lift cylinders and it shouldn't drop a bit with the control valve isolated.'' this part has me stumped.without the seals how can this be? I disconnected the two correct hoses . this eliminated the valve all together. So if the seals in both cylinders were ''good'' then how could oil get past. Even with both cylinders connected together the pressure would be on both cylinder seals. If one or both were worn (30 years old) then the oil would leak past and be in the 'upper' part of the cylinder. Not sure what I am missing here.
/ Cylinder Leak Down test? #8
As rod on boom cylinder travels into cyl barrel the rod will occupy a portion of volume(space) that was occupied by oil that was in butt end of piston barrel. If rod enters cyl barrel then that butt end oil must go somewhere to allow space for rod. Rod can't enter barrel any further due to no available space for cyl rod(shaft) due to presence of oil
  • Good Post
Reactions: LD1
/ Cylinder Leak Down test? #9
As Jim says, what you are missing is that when the cylinder is retracting, in order for the rod to have room to enter the cylinder that same amount of oil has to go somewhere else. That much oil has to completely leave the cylinder.
/ Cylinder Leak Down test? #10
Piston can bypass internally...
/ Cylinder Leak Down test? #11
It can, but it doesn't help. I'll give it another shot. This is worth working on because it isn't easy to see and it is worth the effort.
For this we need a cylinder that doesn't leak where the rod goes into the cylinder..... but most don't leak there and since we've got one here so lets take that cylinder over and put it on our work bench. Take it apart and lets drill some holes right though close to the outer edge of the piston. Drill lots of holes. Maybe about a dozen quarter inch holes all around the face of that piston. That ought to do it. The piston looks like swiss cheese. You can see daylight through it. Dad is going to be really pissed, but hey this is science. There is no doubt that oil can flow from one side of the piston to the other side now. Reassemble it with the piston roughly in the center of it's stroke. Centering it doesn't really matter, but we gotta try to be fair to both sides of our cylinder....
Now with a little funnel we add oil while tilting the cylinder to make sure it is full of nothing but oil - oops, aw crap - first we have to block off the intake and exhaust ports. So we clean up the spilled oil and finish the fill and and Viola! We now have an experimental cylinder full of oil, and the ports are sealed with some NPT bore plugs we found in the plumbing box of spares and inside that cylinder now lives a piston shot full of holes that is going to amaze our friends.
Check me on this......We are sure that no oil can go in or out that we won't see, and with all those holes through the piston there is no doubt that the oil can flow from one side to the other inside that cylinder and it can mix and bypass however it likes. All freely and without any restriction.
OK. It is crunch time. Time to compress the cylinder and to our surprise we find that our rod won't move. "What the heck? The rod won't move!! What's going on?"
Well, we play with it a bit. And we find that by pulling with lots force we can get the rod to extend a few fractions of an inch.... but as soon as we let off it snaps back right to where it was just like there is a giant spring inside. Huh..... weird..... and it still won't compress at all. It just won't. We prop it up and jump on it, beat on it, and finally we wedge it under the loader bucket and really push down on it....but that rod end just will not go into that cylinder.
So now you tell me. What's going on?
rScotty
/ Cylinder Leak Down test? #13
rScotty
But, put two cylinder in parallel as they are usually plumbed on the loader, what happens then?
/ Cylinder Leak Down test? #14
Yes and boom will stay where it's set if control valve holds pressure.
No, you can plug both line ends of cylinder and as piston moves fluid just goes from one side of piston to the other as the rod compresses or extends.
/ Cylinder Leak Down test? #15
This video demonstrates why that's not true if the rod is retracting. You're correct if the rod is extending.
/ Cylinder Leak Down test? #16
All you gotta do is lose a cup of fluid so it has room to move. Best thing is run the tractor and if one cylinder is hot and one is not, rebuild them two. If you dont do both, you'll do the other in two weeks.
You're talking about the volume displacement that the rod causes. Hydrolocking.
/ Cylinder Leak Down test? #17
rScotty
Yes, but if you leave a cup of oil out and get it to move after it hits the oil, you've got a problem. You didn't have to drill holes, just remove the packing.
/ Cylinder Leak Down test? #18
I thought about just removing the packing - or the O rings - depending on which one a particular piston uses. But decided to drill the holes in the piston instead. Partly for the visual, and also because the packing helps keep the piston tight in the cylinder bore. When the piston is tight it can't slop sideways which helps to keep the rod end seal from leaking oil out or air in.
rScotty
/ Cylinder Leak Down test? #19
Please explain if there's a difference in pressure holding capabilities between 2 FEL boom cylinders attached in parallel vs single cylinder if control valve isn't leaking internally. I can't determine any difference in my old feeble brain
Thanks, Jim
/ Cylinder Leak Down test? #20
Same thing. Nothing will leak down due to cylinders.
Incorrect.
It still blows my mind how many people still do not understand this concept.....and further....people giving hydraulic advise and advise on cylinder rebuilding:unsure:
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
