2600H Series (2605H) Front End Loader/Hydraulic Issues
   / 2600H Series (2605H) Front End Loader/Hydraulic Issues #1
atomicflash2006
MF 2605H
I'm a first time poster and first time tractor owner. I have searched up and down on the internet and this forum and couldn't find others with my same symptoms, and none of the proposed solutions for similar issues have worked for me. My maintenance experience up until now has been servicing my riding and zero turn lawn mowers. I'll detail out everything that happened and that I've done so far. Thanks in advance for any help!
I own a Massey Ferguson 2605H 4WD with a 911X front end loader. I bought this tractor new and operated it to the 50 hour mark doing bush hogging and loader work like moving rocks, cut up trees, etc. I have had zero issues with this tractor or the front end loader until I did the 50-hr maintenance. I am convinced that something I did--or failed to do--has caused this problem. From the manual, the major operations required to be performed at the first 50 hour maintenance are changing the engine oil and oil filter, the return oil filter (AGCO ACP0250270 - I have no idea what this is...is it part of the hydraulic system?), and the suction strainer (ACP0475810). These parts I identified between cross referencing the manual with the AGCO website, so it's possible I made an error, but when changing the filters out, the old ones looked identical to what I replaced them with, so I don't think incorrect parts are the issue. Changing the engine oil went fine other than someone at the factory tightened the oil filter tighter than I've ever seen. Changing the return oil filter went fine once I got the housing off. The manual was incorrect/old about how to do this. It listed bolts but instead the design now has 1-3/4 hex at the bottom to twist the housing out. This is shown in the first attached picture. I re-used the O-ring as it looked fine and replaced the filter, and tightened the housing back up.
Next I moved onto the suction strainer, and again found that the housing design didn't match what was pictured or described in the manual, so I had to guess at how to remove it. I removed the bolts on both sides, which drained about 5-6 gallons of hydraulic fluid, loosened the clamps on both sides, and then removed the 3 bolts at the top that mounted the housing to the tractor. I am wondering if I should have just loosened the clamp on the outlet end and only removed the bolts on this side? Anyway, I removed the whole housing, opened it up and replaced the filter. I am confident I placed the filter in the same direction as the previous one, then I put the housing back together and re-attached it to the tractor. This is shown in the second attached picture.
I replaced the hydraulic fluid with new fluid, filling up to the exact middle point on the dip stick between min and max.
I think the 3 point hitch and the front end loader work off of the same hydraulic system, but I'm not sure about the steering. The tractor started up and ran fine, but the front end loader was unresponsive. Oddly, one direction, curling down, worked for one tiny little bump and then it quit too, but all other directions (up, down, curl) didn't work at all. The bucket is resting on the ground, so I can't drive around and test the steering. I researched and asked around and was convinced that the problem was air in my hydraulic system, and most advice said that this will work itself out by exercising the hydraulics. I put about 250 pounds on the 3 point hitch, and the 3 point hitch worked just fine at raising and lowering. It did appear sluggish at first but after ten or so raises and lowering it was working just fine. I put one hour on the tractor, running it at about 1400 RPMs while raising and lowering the 3 point hitch and working the controls of the loader to try to work air out of the system. The whole time, the 3 point worked fine and the loader never responded. At this point I don't know what to do. I can't imagine working the air out would take this long, so there has to be something else wrong.
- Should I go ahead and fill up to max on the hydraulic fluid? I understand you can also have too much fluid, so I wanted to wait before trying this.
- Assuming the 3 point and the FEL are on the common system, what could possibly cause the 3 point to work while the FEL does not?
- what else should I try?
   / 2600H Series (2605H) Front End Loader/Hydraulic Issues #2
unplug loader connections make sure all connections are clean. make sure the ball end of male hose will compress, just press against tractor/fel frame to see.sometimes a hose will seem to be connected, will stay in place under hand pressure, actually isn't connected.
also after unplugging all, with tractor off, cycle loader controls through all positions (including float if it has it) then do the cleaning and reconnect.
any non-flowing connection will exhibit exact same symptoms.
means fluid is not flowing back as it should and you are locked.
ask me how I know and how many minutes I wasted checking fluids and pistons before I figured it out LOL. 30 minutes wasted.
Thanks, this gives me something new to try. I'll post back when I get to it with an update.
I did what you suggested. All connections were secure. I removed all four, cleaned them, pressed all connections. Only a tiny bit of hydraulic oil came out of the housings when I pressed on them. I reconnected all hoses and cranked it back up and no response from the loader. Was there something I should have been looking for on the connections? I think I have a blockage
Update. I removed the bucket with a pry bar so I could move without scraping and confirmed that I have no steering. I guess the steering and the FEL are on the same system. I’m completely lost at this point.
   / 2600H Series (2605H) Front End Loader/Hydraulic Issues #6
I'm no mechanic - just a tractor owner (Mf1540 now) for about 20 years. Just do the basic maintenance myself though.
what I would do is fill up the hydraulic fluid to the full point first and see what happens. It could be just that simple. I have a skidsteer that I was having problems with (jerky movements); turned out it was low on hydraulic fluid.
for what it's worth, I don't think you needed to change the hydraulic fluid at 50 hours. My recollection is that it's usually recommended at around 400 or 500 under normal operating conditions.
   / 2600H Series (2605H) Front End Loader/Hydraulic Issues #7
yeah something is up, on all tractors I've seen all hydraulics are based off the same source just some split off to remotes/etc.
I do wonder if something going on with that return filter, from what I can see on parts list for a 2650H the return filter is a ACP0553640 part number for the whole assy.
from what I can see the element itself is ACP0647840
edit: while not desired, if you happened to put old filter into box and not tossed into dirt/trash (filter will be relatively safe) putting that back into place running a minute or so test will show if its a return issue. if you tossed it around then don't try this.
also maybe calling dealer worth it.
@seville009 I'll go ahead and fill fluid to the max line to see if that helps. Side note, I didn't set out to replace the hydraulic fluid, but since the 50-hr service asked to change the suction strainer, it drained most of the hydraulic fluid as a result of that process. I didn't have something clean to catch it with and wasn't expecting over 5 gallons to come out, so I had to buy new to replace it.
@Dmacleo there's two different kits for this tractor on the return filter, and I think I bought the wrong one because the O-ring was for a different sized housing. I did validate before putting the filter in, though that the filter itself was the same. See pic below. However, I have nothing to lose with trying the old one if you think there might be something potentially defective about the new one. I'm going to open up the suction strainer housing anyway (this time with something large and clean to catch the fluid with) to double check everything is placed correctly in there.
   / 2600H Series (2605H) Front End Loader/Hydraulic Issues #9
well same part# stamped onto it is good but yeah, you mentioned reusing o-ring in first post which caught my eye.
but really I suspect you need to call your dealer.
LOL, I have, he had no idea. Short of trying these few other things suggested, I'm gonna have to have him pick it up for service
2019 F150 (A56438)
2019 F150 (A56438)
2005 TerraGator 8104 (A55302)
2005 TerraGator...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2015 Ford Focus Hatchback (A59231)
2015 Ford Focus...
