"New" Tiller Draw Pins Too Close Together
   / "New" Tiller Draw Pins Too Close Together
I've been to four or five tractor dealers in this area. Longest pins I've seen were probably 6".
OR - have special pins made at a local machine shop. However - having the attachment points for the quick hitch spread that wide could make the entire "hook up" rather fragile.
5030 - has the best suggestion.
That was my concern too. If there were a larger flange to bolt a block of steel to, then it might be easy to extend. Skipping the quick hitch is looking attractive at this point.
Quick hitches have a down side.
Even Pat's are no walk in the park, very wide or very narrow. But I use 'em! ;-)
So I'm learning! ;-)
   / "New" Tiller Draw Pins Too Close Together #13
He could hook up to that implement with Pat's qh , if your lift arms will adjust in narrow enough to hook to it the Pat's qh will work.
   / "New" Tiller Draw Pins Too Close Together #15
Never used a quick hitch or Pats. My lower links telescope on both tractors. No TNT either.
On my small tractor neither one of my lift arms telescope and that's why I like the quick hitch, but on my big tractor both arms telescope and I have no need for a quick hitch.
   / "New" Tiller Draw Pins Too Close Together #17
Cat one is 26"
Cat two is 32"
   / "New" Tiller Draw Pins Too Close Together #18
Double check pto rotation direction and pto shaft length as it may force your decision.
   / "New" Tiller Draw Pins Too Close Together #19
Go to machine shop or steel sales and get something like a 4x4x3/8 (dimensions will very according to implement width) rectangular steel tube and use as a spacer to extend pins out to match you QH ... Modify tiller once to fit QH and be happy forever...
Personally the ease of backing up to implement, raise #PH hitch to engage implement pins and flipping the locks takes less than a minute, would not have it any other way....
You probably have bastardized CAT 0 tiller...
Thank you for the suggestion, DL- I've been noodling along those lines and will take another look with your thought of using a spacer like that. I was also thinking of getting a 7/8" grade B7 threaded rod, and using a Cat 2 bushing over it to reduce likelihood of it bending. But your idea is probably better if I can choose square tubing that will contact more of the mount bracket. I'll look at that today.
I wonder about the Cat 0 idea in that it is a 5'5" tiller. While I don't know much about it that seems like a large attachment to be pulling with Cat 0. Also, the draw pins are 7/8" which leads me to think maybe it is more of a bastardized Cat 1. Driveshaft and clutch arrive tomorrow, so I should be able to connect it directly to the tractor to get started while I sort out the QH connection.
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
1605 (A57192)
1605 (A57192)
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
