If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #871
If one uses the diversity of "effective" life forms found on our home planet as example, ALIENS could look like a great spectrum of possible forms.
Imagine... continuation of life over 100s of MILLIONS of years.
The individual perishes, but the life continues.
....fixed it.
   / If there are aliens, what will they look like? #872
There are more and more engineers waking up to the truth so don't know why you can't believe it.
There's physics and there is theoretical physics.
So answer me this this physics question; how can a vacuum system (space) exist next to a pressure system (atmosphere) without a barrier?
Gravity. Your basic premise only makes sense if the vacuum is surrounded by atmosphere; e.g. a container on earth with all the air pumped out. The barrier is the container, with a powerful driving force, caused by atmospheric pressure, to fill the vacuum.
Assume, arguendo, that the universe is a vacuum; i.e. there are no gasses, only solid objects like earth held together by gravity. The driving force is earth's gravity, holding the gasses on the surface. There is no driving force, i.e. pressure forcing the atmosphere into the vacuum.
   / If there are aliens, what will they look like? #873
I like your thought process. But where does the gravity originate on this rotating sphere (earth) which is moving around the sun all the while shooting through the solar system at outrageous velocities? When we were on a merry-go-round you went fast enough in a circle you would fly off.
Most scientists will say that space is a vacuum.
However, if this magical gravity (which can distinguish the weights of the oceans and birds of the air) exist then you should be able to replicate, in an experiement, the spherical earth where water sticks to it's rotating surface while vacuum and pressure exist next to each other without a barrier.
   / If there are aliens, what will they look like? #874
...AKA 'Pistol Shrimp'. Like a breaching whale, electric eel,...
Pistol shrimp and mantis shrimp are two entirely different species...the former can be found on mud flats etc when the tide is out and rarely get bigger than a man's thumb...mantis shrimp get much larger and I've only ever seen them in much deeper water...on the boats I fished they usually got the "moray treatment"....!
We used to have a saying:
♪♫♪ "He swim in a hole...
and he never let go
It's a moray..." ♪♫♪
   / If there are aliens, what will they look like? #875
I don't know what gravity is, but I can observe it at work. They say the force of gravity is a function of mass of the earth and the thing it attracts. I suspect setting up an experiment might be difficult, if not impossible, because of the minute forces involved in a laboratory scale.
I still say that space does not exert a pressure; the pressure is exerted by the atmosphere, and the driving force is in the opposite direction.
   / If there are aliens, what will they look like? #876
It would be easy to do if you could afford it, find a contractor, and get permits to build a new planet. Can't do it in small scale in a lab because there is no way to isolate the experiment from earth's gravity.
But there is no place to build a near-earth-sized planet inside the dome covering a flat Earth. What's outside the dome? :)
Bruce
   / If there are aliens, what will they look like? #877
What good is a plumb bob if in local gravity vertical isn't what's indicated? (My two point down, not up)
So if the World isn't spinning does that make it flat?
If it is and the North Pole is an axis why aren't we flung South? If it's not, is it the center of Earth? (longitude checks out?)
btw, Waiting to see a map we'd be asked to accept. Is there an 'approved' one vs a globe so many would think is accurate?
   / If there are aliens, what will they look like? #878
There is a distinct possibility that everything you think is real is just your imagination.
   / If there are aliens, what will they look like? #879
The people in power always want to keep the peasants confused and disoriented. o_O
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Flatbed Truck (A55973)
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
