sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,684
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Ah
pic is actual arms
The pin on mounts od is 43.5 so
close to but under kit attach plate ID
I need to keep as much lift capacity as possible, since I move and stack 1500lb square bales 3 high.
It is doable now using my grapple and forks but if I move farther out the grapple may be iffy stacking 3 high
for everything else it has had plenty of lift, 2k pallets are easy on the forks.
if I do have to add a spacer, may have to switch back to the 1200-1300lb hay bales which means a different seller and a lot farther drive.
pic is actual arms
