YM276D Power Steering Linkage
/ YM276D Power Steering Linkage #1
wesmann
Western Massachusetts
YM 276D
There's an inch of play in my PS link. There's a zerk but nothing like a boot. Have I lost a part? Steers fine.
Thanks to everyone who posts to this site.
/ YM276D Power Steering Linkage #2
Have you tried tightening that bolt a little to reduce the amount of play? Or perhaps put some washers in there to take up the slack.
/ YM276D Power Steering Linkage #3
That bolt in the link end looks like a quick DIY attempt to repair.
I suspect a stud snapped off and they welded a nut and used an on hand bolt to re attach.
It is too long and allows the rod end to slide from side to side.
Easiest cure might simply be a new shorter bolt, that or a bunch of washers to close up all the space on the outer side.
That rod end is not supposed to move from side to side.
Thanks - The nut is a lock nut I think. The end of the bolt is flush with the back side of the bracket. The nut was a little loose and I've snugged it up. I might try washers. I'm wondering if there was a spacer originally. I have not been able to find a picture.
/ YM276D Power Steering Linkage #5
The inner 'ball' is never meant to move, all action is the outer section that pivots around the captive 'ball'.
That is but a DIY field repair.
Actually U could drill the back flat piece and snugly bolt that back together and let the ball do its work.
UNUSED INDUSTRIAS AMERICA F12T HYD TILT LAND LEVEL (A62130)
UNUSED INDUSTRIAS...
HD 24ft Free Standing Corral Panel with Feed Bunk (A61166)
HD 24ft Free...
1997 Freightliner FL70 Rollback Truck (A63116)
1997 Freightliner...
7x14 Utility Trailer (A61165)
7x14 Utility...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
2020 Chevrolet Tahoe SUV (A61569)
2020 Chevrolet...
