My Industrial Cabin Build
   / My Industrial Cabin Build #3,211
Hope it works for you.
I always watch your videos, I love the bloopers at the end.
That should work as we use that system for high pressure gas too
   / My Industrial Cabin Build #3,212
Agree on the thread's in today's piping, as any burrs or slivers in the threads will cause leaks and a combo of tape and sealant will fill these gaps.
Short story about pipe taping I will never forget as a Service Tech installing etching and acid cleaning machines for electronics in the early 80's and a machine using 92% Hydrofluoric acid was leaking from the piping fittings. (this acid will eat through skin to the bone if contacted).
Dressed up in a hazard suit gloves etc., took apart the piping, and found that someone at the factory had wrapped the Teflon tape backwards (counter clockwise) causing it to bunch up and split the fittings and leak - could have been much worse - people getting sprayed and all sorts of liability - glad it was an easy fix.
So always wrap pipe tape clockwise.
New video this morning. Installing the submersible pump.
Gonna be shocking the well today after I chase down the leaks.
   / My Industrial Cabin Build #3,214
Is there a reason you don't use a cordless impact driver to really tighten down the stainless clamps on the water connections? It is more torque, easier than a screwdriver.
   / My Industrial Cabin Build #3,215
Can't feel the tightness. Very easy to strip them with a cordless driver unless you have a really powerless driver. :)
With just the screwdriver, I was over torquing them and deforming the band. I had to replace several.
   / My Industrial Cabin Build #3,217
Then I get paranoid and wonder, did I strip that one and just didn't realize it so it'll start leaking in six months???? o_O
   / My Industrial Cabin Build #3,218
Nice job, did you use 2 or three torque arrestors? I see you have one just below the cycle stop is there another in the middle at 100'? Usually you don't need one close to the top with casing there is not much torque or movement at the top and no issue with rubbing against stone/well walls.
On the clamps, the Ideal brand SST HD clamps are what I use on the pump/pipe and heating the pipe molds it around the fitting grooves are what mostly hold the pipe, the clamp just needs to be tight but not over torqued.
   / My Industrial Cabin Build #3,219
Glad to see the in well Cycle Stop Valve:
   / My Industrial Cabin Build #3,220
What;s the benefit of the in well Cycle Stop Valve as opposed to being installed at the tank?
Adams Tender / Magnolia Trailer (A55302)
Adams Tender /...
FLOOR JACK (A55745)
FLOOR JACK (A55745)
New/Unused CFG Industrial MX-MRT14 Mini Skid Steer (A54865)
New/Unused CFG...
Life Proof SPC Luxury Flooring with Soundproof Membrane (A53425)
Life Proof SPC...
2025 CFG SSECAG-Y Hydraulic Auger Skid Steer Attachment with Bits (A53425)
2025 CFG SSECAG-Y...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
