s150 hydraulic leak
/ s150 hydraulic leak #1
gwilkrrs
bobcat 763 and s150
machine has around 1500 hrs on it. after using a grapple bucket a bit i noticed fluid coming from the front right foot hole area in front of machine. after searching i found the control valve assembly on right side and noticed a drip from the bolt head under the solenoid so i took it out but all the o rings look good? now i am wondering if the solenoid above is leaking?
so i pulled the solenoid yesterday to check since i had stuff ulled off anyway.
the 2 smaller o rings on the shaft are good, the big o ring is hard and chipped/nicked and the outside o ring in the recess is loose fitting and nicked.
hopefully dealer has them in stock and they aren't terrible......
i think this is it.
what really shocked me was that none of the treads had any teflon tape or pipe dope on them and only relied on the o rings.....
/ s150 hydraulic leak #5
got it- thanks.
now to find the new o rings-
i can only find a whole new stem but not replacement seals....
/ s150 hydraulic leak #7
any hydraulic shop, bearing supply can find O rings, we have a local bearing supplier that has found us some odd seals over the years, check the local supply guys out
2013 WESTERN STAR 4900 SB MIDROOF SLEEPER (A63569)
2013 WESTERN STAR...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
Hyster H65M Forklift (A64047)
Hyster H65M...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
