My Senior design project - a "Swamp Thing" tracked vehicle clone
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #541
cool project … great engineering/fabrication work it was very cool to go through thanks for sharing … might want to installed a winch before going off-road in case you get carried away but sure with the spans of the tracks it will be unstable.
Yes, I have thought about adding a winch that would be mounted onto a 2" sq. tube so it could be inserted into a receiver welded to the front and rear bumpers. I plan to use the winch to provide the lifting of Snowzerblower.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #543
I've been playing with the cad system and working a bit on my Snowzerblower design which I plan to build over the summer. I plan to use a small compressed air system to pressurize the cylinder which actuates the v-belt take-up pulley. Electric clutches are a bit pricey in this size range.
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #545
I am wondering if the rear end will lift up ? with the weight of the motor and the blower and the leverage of the extended arm up front it will be pretty heavy...
BTW I am really impress with your software skills
I guestimate Snowzer weighs 1700 lbs with a lot of that weight situated towards the rear end due to the Toyota engine back there. That whole assembly calcs to about 275#. I doubt it will have much of an effect. Thanks for the cad kudos. Need something prototyped? ;)
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #547
I've been looking around at some tracked type snow vehicles and debating about building one myself (unfortuantely it will be when I finish up grad school and have more time.) But, just skimmed through most of it and what a great build thread! I appreciate the documentation! I'll have to keep this in mind when I get through grad school and to the point of building or buying one.
Nice work!
I'd be happy to answer any questions about my trials and tribulations building this thing...
   / My Senior design project - a "Swamp Thing" tracked vehicle clone #549
I appreciate that and can only imagine the list that didn't make the thread! :)
Well - I did a couple things this week to Snowzer. I bought and installed a 2500 lb winch (not completely wired yet) and I attempted to weigh Snowzer. I plan to use the winch on both the front and rear of Snowzer so I had to fabricate a 2" receiver for the front bumper and a frame to support the winch. Here's a photo of the installed winch.
Since I do not have a trailer to haul Snowzer down to the local scale, I had to try something different. My plan was to run Snowzer up onto my maintenance ramps (used to let me crawl underneath Snowzer) and then use a small ram from my porta-power set to lift each corner and measure the pressure in the ram. You can see the setup in the next photo. I measured the ram and found it to be about 2.2 sq. in. in area. I then calculated the ram load from the pressure I read. The total for Snowzer was 4200 lbs. WOW! It was way off my estimate. I should have used a lot more carbon fiber when I built it. o_O
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2025 AGT MH12RX Mini-Excavator with Pilot Controls & Dozer Blade (New/Unused) (A59225)
2025 AGT MH12RX...
204549 (A52707)
204549 (A52707)
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
