Tires filled with Beet Juice too heavy for landscaping and field work?
   / Tires filled with Beet Juice too heavy for landscaping and field work? #61
Ohhhhh here we go again ......
At least with wheel weights, you have the option of removing them if you wish a lighter foot print. You don't have that option with filled tires. Will a few hundred pounds make a difference? That could depend on a lot of things, not the least of which being whether the ground is wet/damp or bone dry.
Then we have the debate about weight at the axles or set well behind the axles on a 3 point mount and the difference in leverage.
Most people aren’t going to remove and reinstall 400# wheel weights very often, so they are pretty much the same as loaded tires. Yes it’s an option with wheel weights, but not a quick or easy one.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #62
I loaded the rear tires on my 35HP tractor.
I've used it for landscaping, mowed the lawn with it for years before getting a zero turn.
Never had any issues with rutting.
Early spring when the frost comes out can cause issues, but loaded tires or not I can have issues when the frost comes out
During those conditions, even walking on the lawn leaves dimples.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #63
My tractor is smaller, 33hp, I have never, in over 10 years, felt the need for fluid in the tires. If I'm using the loader I will generally have the rotary cutter on which weighs more than anything I would lift with the loader. I'm pretty good with situational awareness and maybe some people aren't, but I've never had a problem. 🤞
Rotary cutters are great counterweights for lifting 800 pounds, not so much for lifting 2000 pounds.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #64
My tires are loaded. If the ground is soaking wet, loaded isn't going to matter. Either is tread type. I have a Mahindra 1626 with R4 industrial tires which weighs a bit less than yours and if the ground is wet, the front tires which are smaller and not loaded, still leave ruts.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #65
If your tractor can lift 2000 pounds then it already weighs a lot more than 2000 pounds and the water in the bottom of 2 tires isn’t going to make much difference.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #66
My filled tires add 1000# to my tractor. If if lift a ton with my loader I also have my 1000# blade attached. The filled tires make a big difference, providing half the ballast. My dealer won’t sell a tractor with a loader without filling the tires.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #68
It’s not that bad. Most wheel weights are in a series of plates, weighing 50-150lbs. I think mine are 145 a piece. No problem to pull off and lower to the ground. You can use a floor jack to raise them back on if you are not physically able, or a second tractor with pallet forks.
Where there’s a will, there’s a way!
Once fluid is in the tires, it’s pretty much a done deal.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #69
That’s ridiculous of your dealer. He/she is doing a disservice to those who want to use a 3pt weight box, cast rims, or wheel weights, or hang an implement off the back.
Some guys working in rough conditions can’t have fluid in their tires.
   / Tires filled with Beet Juice too heavy for landscaping and field work? #70
You that want it can have your liquid filled tires.
Yes, it costs a bit more initially but I'll stick to my cast iron.
When I got the weights for my Branson the were about a buck a pound, it's around $1.50 per pound.
these are 300# each, but not bad to work with
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2007 LUFKIN END DUMP (A58214)
2007 LUFKIN END...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2013 Cadillac SRX SUV (A56859)
2013 Cadillac SRX...
