Dirt Moving No start issue.
/ No start issue. #1
William S.
2013 Mahindra Gear ,155 End loader 4wd.
2013 Mahindra 5010, run for a lil while and turn off ignition and try to crank and no start, can jump starter and engine will turn over but won't start unless I remove fuel shut off actuator from pump,replaced relays and reworked cables and grounds!!!!!! Anyone had this issue?
/ No start issue. #2
Same tractor gear model..same problem.start as long as key turned, stops immediately.
/ No start issue. #3
How is that a problem? Most vehicles start when the key is turned and shut off when it isn’t.
Do you mean it cranks / turns over, but doesn’t start?
Not turning over versus not starting after it cranks are two very, very different problems.
Not turning over is almost always an electrical component problem. Electricity has to get through key switches, safety switches, relays and solenoids, and many connections, to enable power to flow to (and through) the starter.
Not starting, when it’s turning over, can be many many problems. Often it’s a case of fuel not getting to the cylinders.
/ No start issue. #4
Starts with key in start position, stops immediately when release start to run position.
/ No start issue. #8
If it’s a 3 wire solenoid, it’s possible the solenoid itself has burnt up the “hold” coil inside itself.. There are 2diff coils, 1 pull in coil and 1 hold coil.. they’re also controlled by relays..
It could be the relays, the solenoid itself or the key switch..
Whatever you do, don’t try to “hot wire” the solenoid inorder to run it..you’ll definitely burn up the solenoid for sure..
I can tell you how to test the solenoid to eliminate that..
Lemme know if you need instructions.. or you might find it on utube..
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
RIDGID 8000 WATT GAS GENEATOR (A65055)
RIDGID 8000 WATT...
UNUSED FUTURE FTL75-75" HYD FORKLIFT TIRE LIFTER (A65055)
UNUSED FUTURE...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
